![]() | Home > In Car Electronics > Tapping into reverse light - how? |
newton-tony Member Since: 18 Sep 2016 Location: Wiltshire Posts: 124 ![]() ![]() ![]() |
I just removed my reverse light, plus the panel to the left of the rear door and was able to pass the wire through and splice
seriesonenut Member Since: 19 Nov 2014 Location: Essex Posts: 1256 ![]() ![]() |
That's how I did it as well. I added a fuse at that point so I could be sure the RL would not be impacted by the camera in the future.
![]() 2010 XS USW (sold) 1957 Series One 88 diesel 1958 Series One 88 4x2 1990 Defender 200tdi CSW (sold) 1989 Land Rover Ninety (sold) 1998 Discovery 2 (sold) 1995 Discovery 1 (auto) (sold) 1990 Discovery 200tdi (sold) 1987 One Ten CSW turbo diesel (sold) |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20979 ![]() ![]() |
You can either remove the reverse light and feed though there and then reach in from under the wheel arch to up behind there to the grommet behind the plastic mud shield.
I'm guessing your issue your asking about is how to thread the signal feed though the panel grommet? If so I've done this just yesterday. Use a stiff wire or in my case I used some old surplus pvc tubing, threaded down from behind the speaker panel until you can reach it behind the mud shield also. Ideally long enough to be easily accessible. Then you can attach the feed you want threaded though to the wire or similar with something like electrical tape and carefully draw it back up though where you want it behind the speaker panel. I terminated mine there with a 1pole Superseal with a capped /sealed plug on that's fiitted for the time being until I want to use it. Then plug and play ready to go and even waterproof too. (With fuse in-line.) The wire threading is tricky I admit, but easily doable. In my case and the same should apply to you also, you should be able to leave your reverse light alone and do it all from the rear just below the mud shield. Just make sure the Econoseal plugs stay clean especially if temporarily disconnected. (But this depends if you have factory reverse light or LED aftermarket.) If factory, then you likely will need to remove the reverse light too for better access and easily done? I can't reach mine in situ due to being after market LED. ____\We|Will|Win/___ ____/🇬🇧🇺🇸\____ _//*⛽ï¸ðŸ›¢ï¸âš™ï¸ðŸ§°*\\_ |
NickMc Member Since: 01 Oct 2014 Location: Norn Iron Posts: 1681 ![]() ![]() ![]() |
I'd use the crimp connectors with the heat shrink and glue (not the solder type the dont seem to last) as this area always collects dirt and moisture, id say its one of the most common faults i see on Defenders week in week out- corroded or damaged rear light wiring.
MussEd Member Since: 20 Feb 2013 Location: East Lothian Posts: 370 ![]() ![]() ![]() |
Great stuff folks. Fitted a load of soundproofing and carpet earlier in the summer so that speaker panel will be a right pain to
remove. And that’s before worrying about the wire manoeuvres...maybe just stick to using the NAS step as a parking aid! |
When I needed to do this, I used a male and female Econoseal connector to make up a short lead to fit between the existing wiring and lamp that included an extra, loose, wire to the positive terminal. This extra wire was then passed up through the rubber grommet in the wheel box above and taken to where I needed it.
I haven't got a picture, unfortunately, but I have got this of a similar lead that I made up to take feeds from the stop and tail lights, which should give you the idea: ![]() Click image to enlarge In this general view of the area behind the nearside speaker panel, the yellow wire is the tapped feed from the reverse light and the black connector in the centre is the one shown above that taps the stop and tail lights: ![]() Click image to enlarge Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5999 ![]() ![]() |
Pinched mine from the tow bar electrics.
leonvh Member Since: 31 Dec 2013 Location: Plombières Posts: 70 ![]() ![]() ![]() |
My initial setup with the reversing camera was also using a signal from the reversing light. But when maneuvering backwards and forwards the image would keep switching on and off all the time. Very annoying, so now I use a simple switch to activate the image from the reversing camera on my screen. One extra action is needed, but for me it has only benefits as I can also use the camera when not in reverse...
That looks amazing but far too involved for my meagre talents and limited skills! The tow bar electrics are right next to where I Intend to mount the camera so that option makes sense... |
I did much the same as LRA did too. It works well.
I’d have thought if you wanted a permanent rear cam and reverse feed auto on all you’d need to do is the reverse signal would auto turn on. If the rear cam is permanently live with ignition on simply select as a source on the HU and it will be on. If the HU has video source reverse in and a source 1 in or 1 & 2 in additional then just use a video RCA Y splitter. But yes, you can use a switch if you want as well. Even an On 1 with reverse only / Off / On permanent. ____\We|Will|Win/___ ____/🇬🇧🇺🇸\____ _//*⛽ï¸ðŸ›¢ï¸âš™ï¸ðŸ§°*\\_ |
jeffersj Member Since: 23 Jan 2015 Location: Near Preston Posts: 431 ![]() ![]() ![]() |
I would like to get that earthing bracket shown on the photos to improve the earth in the 300Tdi, any idea of the part number or is it widely available elsewhere? Jeff
Ex 1968 Series 2A Ex 90 TD5 Ex D3 Ex D4 |
That's just an offcut of some aluminium angle that I cut to size, drilled full of holes and bolted to the tub (having first cleaned off a bit of paint to ensure a good contact). Darren
