![]() | Home > For Sale & Wanted > [Wanted] Steel Stockists in Bristol/Bath area |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17954 ![]() ![]() ![]() |
A quick Google produces quite a few possibilities. Does it need to be a single continuous 7m length? Do you require a CofC with it?
walfy Member Since: 29 Aug 2007 Location: Frome Posts: 2702 ![]() ![]() |
I had a google as well but my present experience of going with a stockist through work thinking it would be an easy solution was wrong.
Perhaps I should of clarified my post, does anyone have knowledge and used a reputable steel merchant. CofC, I'm assuming certificate of conformity? If thats correct then no I dont. As for 7m, when I was ordering through the company they said it came in 7m lengths as it was a special order. I need about 5 or 6m but thought that the 7m would give me 1 cock up when cutting. The reason, I have a Polaris RZR and managed to have a little incident with it and went end over end and bent the cage slightly, so new front hoop which I have, just need the roof rails replacing in 38mm tube. 110 D250 SE HT 110 USW SOLD RRE HSE Dynamic Gone, wife killed it VOLVO XC60 R Dynamic with some toys Polaris RZR 900XP SOLD |
5.7 m seems a common length, hence my question. Yes CoC is a certificate of conformity, most f the stuff we do (loco boiler work) requires them. I'll ask about and let you know.
Many thanks.
1 thing I have learnt in my searches is the difference between pipe and tube. Who'd of thought that they would measure it differently 1 being inside dia the other outside dia. Why can't they just make it easy and everyone measure tube/pipe the same? 110 D250 SE HT 110 USW SOLD RRE HSE Dynamic Gone, wife killed it VOLVO XC60 R Dynamic with some toys Polaris RZR 900XP SOLD |
gcc130 Member Since: 05 Jun 2015 Location: Wiltshire Posts: 787 ![]() |
Have you tried Devizes Steel Supplies?
Not sure if they’ll have what you’re after but I use them regularly. Also not the cheapest but worth a try. |
Because that would be far too easy! ![]() |
