Home > Maintenance & Modifications > Cross Member bolts
Grapax
United Kingdom 2014 Defender 110 Puma 2.2 XS CSW Alaska White
Cross Member bolts
Hi I am after replacement bolts in stainless steel for rear cross member.
Anyone know what the part code might be?
I think the bolts are M10 120mm
Ideally I am after set of 4 with washers and nuts included. Many thanks
Post #787611 19th Aug 2019 12:53pm
Sulisuli
Try Brendan at https://www.4x4overlander.com 2015 HT XS 90
2008 SVX 90
2000 XS TD5 90
Post #787613 19th Aug 2019 12:59pm
rallysteve
M10x110. Just order some A4-80 ones from a local fastening supplier or online. I have used Westfield many times:
https://www.westfieldfasteners.co.uk/Bolts...nless.html
Post #787615 19th Aug 2019 1:09pm
Grapax
Thanks for the quick replies so far
Post #787617 19th Aug 2019 1:13pm
discomog
I would echo Rallysteve, either Westfield Fasteners or https://www.s3i.co.uk/screws-and-bolts.php Defender 90XS SW
Mini Countryman Cooper S
Morgan Plus 8
Post #787685 19th Aug 2019 4:59pm
It's only a personal opinion, but personally I would not replace bolts that secure the rear seatbelts with stainless.
(In fact I generally wouldn't replace any ferrous fasteners with stainless, but that is a different story).
Post #787713 19th Aug 2019 6:23pm
Zed
Westfield or YRM.
Post #787714 19th Aug 2019 6:24pm
Grapax
Hi Blackwolf
I didn’t realise the bolts had anything to do with the rear seat belts on a 110 but I’ll take your word for it.
If I don’t replace with stainless then any idea where to get replacement m10 x 110 flange bolts from - I cant seem to find then easily
Post #787738 19th Aug 2019 7:35pm
90 Dreamer
Look for a local 'fasteners' type place and they will most likely be able to assist
Post #787740 19th Aug 2019 7:39pm
Balvaig
Dan at Duckworth parts was offering these LR bolts in one of his recent posts.
Worth sending him a pm if you want original.
Post #787786 19th Aug 2019 9:34pm
Presumably, you want to replace them for the aesthetics? If so, why not clean up the originals in-situ and paint them a suitable colour? Getting them out can be a bit of a pig of a job. Darren
Post #787831 20th Aug 2019 7:35am
Grapax
Thanks for the recent comments
Post #787921 20th Aug 2019 7:05pm
bankz5152
Why?
Post #787925 20th Aug 2019 7:22pm
90 Dreamer
Stainless is generally very brittle and certainly not ideal in a 'stressed' situation.......
Post #787929 20th Aug 2019 7:25pm
Firstly because SS anywhere round aluminium alloys can initiate horrible corrosion and chemical welding phenomena, and secondly because unless you can ensure that you obtain A4-316 fasteners they will be less strong than the 8.8 that you take out. Then there is the absence of elasticity inherent in stainless steels, meaning that they break rather than stretch.
I would rather deal with a rusty 8.8 fastener than a cold welded stainless one any day.
Post #787930 20th Aug 2019 7:41pm
