Home > Puma (Tdci) > Exhaust Mid Box
keef9t
United Kingdom 2007 Defender 90 Puma 2.4 HT Stornoway Grey
Exhaust Mid Box
The exhaust mid section (standard mild steel) is off while I remove the transfer box. It's not in good condition so I am considering replacing it. Does anyone know of an "off the shelf" straight through section in mild steel.
Sorry, should have mentioned it's a Tdci 2.4 90 H/T
Post #787702 19th Aug 2019 5:52pm
NickMc
Personally wouldnt bother the drone of removing it will put your head away in the long term Laughing Whistle
Post #787720 19th Aug 2019 6:45pm
landy andy
I’d remove it. I bet you can’t notice the difference. I haven’t on either of the 110’s I’ve owned. Plenty of cheap ones about.
Post #787730 19th Aug 2019 7:11pm
BenB8man
United Kingdom 2010 Defender 110 Puma 2.4 DCPU Stornoway Grey
I wouldn't say it's much louder at all without the midbox. Certainly not a drone, but maybe my tyres hide the noise.
https://www.ebay.co.uk/itm/LAND-ROVER-DEFE...SwHrlcJe9z
Post #787732 19th Aug 2019 7:14pm
NickMc
Each to their own, i had one on my old tuned td5 and took it back off, couldn't take the noise on the long journeys.....whered i put my pipe and slippers Rolling with laughter
Post #787737 19th Aug 2019 7:27pm
BenB8man
Ah, that might be a TDCI vs TD5 thing.
Post #787745 19th Aug 2019 7:53pm
Co1
Just given one away!! I had the straight through pipe and it makes no difference to the noise at all. The dpf does that for you.
Post #787749 19th Aug 2019 8:02pm
landy andy
90 yes a difference 110 no difference Td5 or Tdci that’s my experience.
Post #787770 19th Aug 2019 8:48pm
NickMc
That'll not be all tdcis though.
Post #787777 19th Aug 2019 9:07pm
BenB8man
Am I right in thinking that the 2.4's didn't have a DPF, only the 2.2's?
Post #787807 19th Aug 2019 10:38pm
LR90XS2011
No DPF on a 2.4 Ive done it on mine worth doing just to save the weight. At idle it has a nice deeper tone , above idle no noticeable difference in noise. I brought terrafirma but it was a mare to fit as the angles at the end were all wrong and I had to cut off and reweld the hangers buy a better make DEFENDER 90 TDCI XS,
Post #787825 20th Aug 2019 6:28am
keef9t
Thanks for your comments.
Has anyone bought one that fits without having to modify to fit.
Post #787941 20th Aug 2019 8:25pm
Co1
The cheap SS one from paddock fits just fine. Don’t forget gaskets as well; 2 bolt for one end, 3 bolt for the other.
Post #787987 21st Aug 2019 6:14am
