Home > For Sale & Wanted > [For Sale] Factory Fitted 110 Chequer Plate Set/Kit; Black |
hank Member Since: 12 Sep 2016 Location: South Wales Posts: 2218 |
For sale is a set of factory fitted JLR chequer plate to suit 110.
These began life silver but were professionally prepped, etch primed and powder coated satin black by PCL (ISO 9001 certified www.polhampowdercoating.co.uk) around 18 months ago. The rear tub panels are the 'low line' type. Also comes with countersunk black stainless bolts and stainless nyloc nuts to fit. Since having the m coated I have de-chequered my 110... - The sills were never fitted so condition is perfect - The wing tops did around 1500 miles and are also perfect - The rear tub panels also did around 1500 miles - the nearside one is perfect, the offside has a small touch up after a carpark incident. Not bad and not noticeable when fitted. Refer to penultimate photo. £150 collected from Newport, South Wales. Bear in mind the powder coat alone cost more than that! I will consider couriering but due to size, shape, weight and the quantity of bubble wrap they will require to protect against damage this is likely to be around £25 Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge > 110 XS Double Cab > Instagram @simonlanemind |
6th Aug 2019 2:16pm |
14th Aug 2019 6:20pm |
Intercept Member Since: 27 Feb 2017 Location: Suffolk Posts: 587 |
Items arrived as described - many thanks for an easy transaction
18th Aug 2019 7:49pm |
