Home > Maintenance & Modifications > Reverse light to rear speaker panel |
rallysteve Member Since: 10 Feb 2014 Location: Cumbria Posts: 2200 |
Should be as it is where the LH tail light and brake light wiring passes through.
Steve 02' 110 TD5 Double Cab Rebuild Thread 84' 90 3.9 V8 Caged Pickup Build Thread - Now For Sale |
12th Aug 2019 3:58pm |
Yes, definitely. You can see them in this pic of some of my additional wiring:
Click image to enlarge Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
12th Aug 2019 7:03pm |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 19600 |
Awesome, thank you both of you.
You never know with LR and their wisdom if they'd have brought the feeds in one side, up and over and back down. I rarely ever access that side so that's very helpful indeed. At some point I need to get out the seized screws holding the plastic protective panel up underneath too. You guessed it, seized solid and the cross head on the screw will slip. I'd have thought I might have to either get some kind of extractor bit for these or carefully grind the screw heads off so that the panel can come off and remove the rest of the thread with pliers. I've tried getting behind to try and wind them out but they are steadfast holding on there. On of the reasons I try an avoid using screws with such a head. I can probably reach up behind anyway for feeeding the reverse feed though, but these sort of things are a real pain. Ideally the fuel tank breather needs to go up behind there as well. Diesel$ Live$ Matter. ⛽️🛢️👨🔧🧰⚙️ RED, WHITE & BOOST! 🇬🇧 |
12th Aug 2019 7:31pm |
