Home > Puma (Tdci) > Operation and unstable fuel pressure
Fernando
Argentina 2008 Defender 110 Puma 2.4 SW Bonatti Grey
See if you can guide me to solve this problem!
ith the engine regulating, the operation is unstable, with the nanocom connected, it marks unstable fuel pressure, what may be happening ???
regards
Post #786204 11th Aug 2019 2:44am
Bluest
The VCV, or suction control valve controls pressure to the fuel rail. They do wear out and usually cause unstable idle. When mine was having problems the Nanocom showed the fuel pressure fluctuating a lot, but their was no fault code. They are easy to replace. 2007 110 TDCi Station Wagon XS
Post #786209 11th Aug 2019 8:02am
williamthedog
If it's the vcv valve buy a genuine one, denso make them Thumbs Up
Post #786216 11th Aug 2019 8:15am
MK
What sort of fluctuation are you reading? @ rpms? Puma 110" SW
Post #786260 11th Aug 2019 1:45pm
Fernando
r.p.m without increase, only at times uneven operation.
The vcv valve changed 6 months ago for a dense one !!!
Post #786392 11th Aug 2019 10:00pm
HardCharger
Maybe air is getting into the system? Check if your fuel filter is on secure and does not wobble when you try to move it. Check all connecting points in the fuel system to see if you can spot a leak or one that is not correctly secured on.
It could also be the copper washers and o-rings of the injectors.
Post #786437 12th Aug 2019 11:00am
Fernando
I lean to the vcv valve, the toric seals and the copper washers were changed, the filter is firmly in place.
It can be the valve LR006866 ??
Regards
Post #786440 12th Aug 2019 11:16am
