Home > Puma (Tdci) > Why can't LR make decent wiring harnesses?
Page 2 of 2 <12
Grenadier
First, thank you BW and DS.
Second, i wouldn’t have had a scooby if that had happened to me.
Third, I’d have been ragging it imagining I had a wide-bore exhaust fitted. Maybe even a V8 Whistle Rolling with laughter Monsieur Le Grenadier
2011 Puma 110DC - Corris Grey
Post #786176 10th Aug 2019 7:24pm
dorsetsmith
Why can't LR make decent wiring harnesses? too save 50p Whistle
Post #786181 10th Aug 2019 8:00pm
Rashers
Rolling with laughter Rolling with laughter Rolling with laughter
"Value Engineering"
Post #786182 10th Aug 2019 8:04pm
90 Dreamer
Looking at some of the other stuff they must have saved more than 50p............. Rolling with laughter
Post #786183 10th Aug 2019 8:04pm
Ramsay
Scotland 1995 Defender 110 300 Tdi CSW Auto Keswick Green
Poor work instructions. If wires had been looped around ferrite before termination all would have stayed in place. Once terminated needs additional parts to secure the core and they will not have been on BOM. Poor execution by sub contractor and poor QA by Land Rover. It may be that PPAP part was OK but other operators did not follow the same plan. 1995 Defender 110 CSW
1971 SIIA Lightweight
Post #786185 10th Aug 2019 8:15pm
What does the Ferrite ring do? Dampen EMF or similar? (I assume.)
Thanks for the heads up. I shall check mine sometime.
A tiny bit of light oil on the turbo actuator pivot points is also useful I find but that’s a different issue.
The trouble is with the Puma motor and harness is there is a lot of vibration and movement present even without rough terrain.
Poor quality roads just add to it even more ____\We|Will|Win/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #786197 10th Aug 2019 9:46pm
Post #786201 10th Aug 2019 10:42pm
miker
At least that was fairly benign... About 6 months ago, the 2.5mm power wire feeding the bbus shorted to the inner wing on mine, a 2.5mm wire that is fused at 50A....
What followed was a lost of smoke, much charred wiring and very nearly a fire in the engine bay. All at about 1am, and only noticed as I happened to be working nights and all my lights powered themselves up in the carpark!
Post #786203 11th Aug 2019 12:44am
MK
pls delete
Does it really need configuration on a 2.4?
 Puma 110" SW
Post #1040397 19th Jul 2024 11:04pm
Page 2 of 2 <12
