![]() | Home > Technical > Ignition switch |
| oneten110 Member Since: 02 Jul 2011 Location: Wish I was still in France Posts: 741
Mine is 34 years old and still working well, on a vehicle that has done over 385,000 miles.
If you have already identified, and repaired, the fault. Why give yourself additional work? |
| dioliahary Member Since: 18 Jan 2015 Location: Manchester Posts: 668
Now changed as the repair was temporary, 34 yrs old makes mine seem Like a teenager 😂 1990 200tdi conversion 90
| Pilgrimmick Member Since: 16 Nov 2015 Location: Highlands Posts: 582
I am having problems with my tdi ignition, suspect the switch. Quick check of Haynes, states thatI need to remove the steering lock to access it. This does not seem right to me.
So does anyone know how to change the ignition switch, without removing the steering lock? Cheers 80" 1948 Lightweight V8 Bowler Tomcat 130 Station wagon 90 300tdi (Santana PS10 pick up) Range Rover L322 (Ful fat) |
Given that the electrical element of the ignition switch (rather than the key part) is only retained by a small screw. Then yes it should be possible to remove that element without removing the steering lock. You can be assured that access to the screw will try your patience though and will require the removal of the steering column shroud and probably most of the instrument panel.
https://www.brit-car.co.uk/product.php/455...h_defender It is not a Defender, it is a One_Ten |
| All times are GMT |
