![]() | Home > Technical > Fishy smell coming from fuel cap? |
| jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8489
do you use an additive? Cheers
| deaallen Member Since: 15 Feb 2016 Location: Basingstoke Posts: 267
Nope, never have
| Sulisuli Member Since: 30 Oct 2016 Location: South west Posts: 4808
What kind of mileage do you do annually? 2015 HT XS 90
2008 SVX 90 2000 XS TD5 90 |
Only around 8k - I use another two cars as my daily drivers
I did wonder if the diesel was deteriorating in the tank giving off the smell you describe but given the mileage you do that can’t be the case.
Is it the rubber filler hose that is giving off the odour? 2015 HT XS 90 2008 SVX 90 2000 XS TD5 90 |
I'm not really sure, its hard to tell but it seems like its coming from the optimil fuel cap, that has a rubber oring in it so maybe its that, but whenever I take it off the smell lingers on my fingers shortly after aswell
I too have an Optimill fuel cap so I guess I need to go outside and sniff mine now
| Swine&Small Member Since: 20 Mar 2017 Location: Norfolk Posts: 1223
Bicycle seats next
1967 Morris Traveller 1966 Morris Convertible 2012 VW T5 Camper Quod Abundat Non Obstat. |
Well I can confirm that mine doesn’t smell fishy
| NickMc Member Since: 01 Oct 2014 Location: Norn Iron Posts: 1681
That’s snake oil- not fish oil |
| Dutch Guy Member Since: 13 Nov 2017 Location: Hekelingen Posts: 16
my best guess would be you refueled using biodiesel (blend of diesel with FAME) derived from UCO - short for used cooking oil. In the land of fish and chips I would assume that will be fishy....
It is well known that FAME has a tendency to affect parts made out of polymers, rubbers etc. |
| gilarion Member Since: 05 Dec 2013 Location: Wales Posts: 5142
Oh! dear
It sounds as if you are suffering from Trimethylaminuria ('fish odour syndrome') Trimethylaminuria (TMAU) is an uncommon condition that causes an unpleasant, fishy smell. It's also called "fish odour syndrome". There's currently no cure. Symptoms of trimethylaminuria Trimethylaminuria symptoms can be present from birth, but they may not start until later in life The only symptom is an unpleasant smell, typically of rotting fish Things that can make it worse include: sweating stress certain foods – such as eggs and beans The NHS advises seeing a GP if you notice a strong, unpleasant smell that doesn't go away. For those who like Welsh Mountains and narrow boats have a look at my videos and photos at.. http://www.youtube.com/user/conwy1 |
| Rashers Member Since: 21 Jun 2015 Location: Norfolk Posts: 3668
Let me be clear, it is only my defender suffering Trimethylaminuria, not me |
| All times are GMT |
