![]() | Home > Puma (Tdci) > 2010 2.4 tdci 90 Rear Disc change help required. |
B4Lamb Member Since: 21 Mar 2015 Location: Abergavenny, Wales Posts: 233 ![]() ![]() ![]() |
Thank you all above for the excellent information and advice.
I'll definitely convert to the two nut solution if I find it's not been done already. As it's been said it's a no brainer. Why on earth did Landrover change to a staked nut I've no idea. It's not like the hub and discs will never need any maintenance. The engineer probably received a bonus for saving 20p per car. The caliper bolts are definitely 12 point and I do have a set of these socketa. The main reasons for this job is to replace the pitted and scored disks and to fit new calipers as I have corrosion and sticking pistons. "You are never to old to learn something new" |
NickMc Member Since: 01 Oct 2014 Location: Norn Iron Posts: 1681 ![]() ![]() ![]() |
I normally re-pack the bearings and stick a hub seal in when I do them, for how little it costs.
Yes definitely agree. While it's all apart. Good idea "You are never to old to learn something new"
lonewolf Member Since: 23 Oct 2013 Location: North East England Posts: 210 ![]() ![]() ![]() |
I agree with ^ grease repack and new seal, doesn’t cost the earth.
Thanks to all who replied to my original post.....cheers folks. |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8323 ![]() ![]() ![]() |
You don't need circlip pliers, leave the shaft on the drive member as they will be two piece. And just remove both together. Cheers
