Home > Td5 > Delayed throttle response
Paullr90
United Kingdom 2003 Defender 90 Td5 XS CSW Bonatti Grey
Evening guys, anyone had this before?
I'm getting about a second delay in throttle response. It's most noticeable when pulling out a junction shifting up the gears the engine continues at high revs when the clutch is dipped before dropping off as usual and then it's slow to build up the revs again.
I've already changed the injector harness and fitted a new throttle pedal but that hasn't had an effect. I'm now wondering if it's a clutch problem?
Anyone any ideas?
Cheers,
Paul. 2003 Td5 90XS
1970 Series 11A 2.25TD
2013 Freelander 2 HSE Lux (the wife's)
Post #784287 31st Jul 2019 10:03pm
landy andy
Does it think it is in low range on the transfer box?
MAF always effects acceleration, but wouldn’t cause it to hang onto revs, but unplug and try.
Is it the same when on tickover? With mine the slightest touch of the pedal gets it reving
Post #784302 31st Jul 2019 10:36pm
Vogler
Belgium 2015 Defender 110 Td5 HT Chawton White
Most likely the clutch pedal switch / fuel cut-off switch is defective. For the Td5 it's part MSK500010. It sits on top of the clutch master cylinder.
Mind that it is not compatible with its Td4 counterpart, although they look the same.
Regards,
Joris Antares Treadwell, a MY06 110 Td5 in Chawton White
Post #784360 1st Aug 2019 12:59pm
excossack
Mine is much better after having new injector seals and the timing set correctly. Still have a delay but not as bad as it was. Low revs/1st gear starting off is better as well. 1999 Defender TD5 110
Regards
John M0VAZ
Econet Station 48 no clock
Post #784368 1st Aug 2019 1:34pm
roel
I drive with the clutchpedal sensor disconnected. You can try that. Or if that doesn't help short the connector you pulled off the sensor. If both do not solve the problem then it is not the clutch pedal sensor. Roel
2003 90 Td5 (2009-now)
Post #784482 2nd Aug 2019 7:30am
Paullr90
Regards,
Joris
Thanks Joris. I took the connector off to find it full of oil. Looks like the seal must have gone and this caused the clutch pedal switch to short. Got a new switch on order so fingers crossed that's it solved.
Thanks again.
Paul. 2003 Td5 90XS
Post #784798 4th Aug 2019 10:41am
roel
Without the plug connected, is the problem gone? You can drive it this way, the ecu doesn't really need the clutch signal. Roel
Post #784889 4th Aug 2019 7:57pm
