![]() | Home > In Car Electronics > Lost link to v nice cruise control |
| Minch90 Member Since: 15 Sep 2017 Location: Gloucestershire Posts: 248
Similarly v tempted - would be good to see fitting instructions first... 2.4TDCI 90 - everyday brilliance
S3 V8 Lightweight - in the garage being ignored #newchassistime S3 lightweight - 2nd car 24V fire risk with a full tilt and the windscreen down S1 80" - first car fun - 75mph in neutral downhill once #wobblesallround |
| Grenadier Member Since: 23 Jul 2014 Location: The foot of Mont Blanc... Posts: 5895
Depending on what we hear back and given how many of us are interested, they do a discount for a bulk buy. Worth considering, even if it only saves enough for a couple of jars..
RRP: £185 x5: £175 x10: £169. If they have a commercial bone in their body, sure they’d be happy to get a bulk buy from a forum as important as Def2? Monsieur Le Grenadier I've not been everywhere, but it's on my list..... 2011 Puma 110DC - Corris Grey |
| Ads90 Member Since: 16 Jun 2008 Location: Cots-on-the-Wolds Posts: 813
^ If it checks out, I'd be interested...
| Matt110 Member Since: 29 Jun 2014 Location: UK Posts: 688
Got the feedback. Could anyone who's fitted the alternative systems we normally all refer to from mobile centre etc have a look and see if it looks similar and if there's any pitfalls?
This was the reply on the bending the wire..
And I'm just figuring out how to upload the pdf file of the installation instructions! |
| Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6727
https://www.defender2.net/gallery/upload.php or email to me martin@defender2.net
1988 90 Td5 NAS soft top
2015 D90 XS SW |
5mm not much.... Monsieur Le Grenadier
Thanks Martin. Think I've done this right apologies if not. INSTALLATION INSTRUCTIONS FOR 2.4/2.2 https://www.defender2.net/gallery/albums/u...07%20-.pdf |
| Mike_E Member Since: 13 Apr 2017 Location: Aberdeenshire Posts: 161
well done chaps.
As the 2.2 runs CAN bus - does it mean you can get away without the manual wiring required to all the inputs? bit confused as the instructions show a load of connections for clutch, speed, brake etc but in the text it says you only need that if there is no CAN bus? or is the "use this for 2.2D" on page 3 meaning its just a tap into the clutch wire that is required? Thanks Mike |
No a 2.4 and 2.2 will need the hard wiring, not CAN. The clutch/brake signals aren't transmitted on CAN on Pumas.
Strange they don't have a page for the 2.4 clutch switch 1988 90 Td5 NAS soft top
2015 D90 XS SW |
They agreed.....
"The only detail that the Cruise could use that is present on the Defender CAN system would be vehicle speed and given that manual connections for Brake and Clutch detection are already required, using CAN to read the vehicle speed isn't viable as this would entail 2 additional wire connections, whereas reading the analogue speed signal is just one wire connection. Best regards George" Gives good confidence they know their field! |
| Roy5695 Member Since: 15 Feb 2014 Location: Cornwall Posts: 1123
It’s in the shopping list.
Instagram - @r22oyp Roy |
| bluebottle Member Since: 08 May 2015 Location: Not in my Landy enough! Posts: 705
Since they seem to do a TD5 version I would be interested in a group buy as well - provided they can mix and match?!
Now all I have to do is work out if I’m a 6 wire or a 7 wire throttle... presumably this is as easy as it sounds and I just count the cables in the plug (or given Solihull QA there’ll be some unsheathed portion of cable where I can count the strands...) |
