Home > Maintenance & Modifications > None electrical Puma
Oldyellar
Scotland 2015 Defender 90 Puma 2.2 XS CSW Corris Grey
This is a non common rail 2.4 puma engine out a transit running on a manual fuel pump as opposed to a fly buy wire I reckon it would be a neat conversion
Post #783661 28th Jul 2019 8:20pm
Oldyellar
Its actually a 2.0 puma out a transit now I look more closely
Post #783662 28th Jul 2019 8:27pm
dgardel
Italy
It's the 2.4 marine version Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #784088 30th Jul 2019 6:07pm
HardCharger
So, can we use it in the Defenders? Will the power output be better? Easier to drown proof, I'd expect.
Post #784149 31st Jul 2019 3:34am
Mo Murphy
Why do people think it would be better ?
50 Shades of Pennine Grey
Post #784175 31st Jul 2019 9:00am
HardCharger
No electronics?
Also, I think it would be simpler to just install it in place of the electronic Puma? I'm just spitballing here.
IF it's the same or better than the electric 2.4 Puma then it could be a viable option for longevity and perhaps durability?
Post #784177 31st Jul 2019 9:13am
dgardel
Italy
Shocked it's a step (more than one) backward...
Less combustion controls, less power, lower efficiency.. Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #784181 31st Jul 2019 9:29am
Mo Murphy
Surely it would be cheaper and considerably less effort to fit a Tdi engine if you are that excited about a mechanically injected engine ?
Post #784183 31st Jul 2019 9:34am
I imagine that it is entirely non-compliant with emissions regs, since (as far as I know) boats still enjoy a more relaxed regime. Its performance (in terms of torque and power curves) is also probably completely different and unsuited to road vehicles.
I really cannot see any reason why you would want to fit a marine engine in a road vehicle!
Post #784184 31st Jul 2019 9:43am
DonH2000
United Kingdom 2009 Defender 90 Puma 2.4 XS CSW Santorini Black
"I really cannot see any reason why you would want to fit a marine engine in a road vehicle!"
Remember the old Rover V8 was a Buick engine in the 1960's that was fitted to a boat when Rover first bought the rights.
"It was Rover's Managing Director, William Martin-Hurst, who managed to source the 3.5-litre V8 engine, having cast far and wide for something suitable - and finding it by accident in an American boatyard. Knowing that the engine was being phased out by General Motors, he approached the company, offering to purchase the rights to build it. The deal was certainly an audacious one because of the fact that it involved an outright payment to the American multi-national, thereby avoiding further royalty payments in the future. The deal was hammered out during the winter months of 1964 and by the following January, the engine was the property of Rover."
https://web.archive.org/web/20071008203751...verv8f.htm Cheers Don.
Post #784225 31st Jul 2019 3:26pm
Indeed, but that was not designed as a boat engine, it was a redundant vehicle engine someone had installed in a boat.
Post #784243 31st Jul 2019 5:16pm
Oldyellar
Definitely a step back from the tdci pump but alot of steps forward against the older td, TDI and none turbo engines plus you can have the 6 speed box
Post #784262 31st Jul 2019 8:22pm
Mo Murphy
Trouble is its not just the pump. It's bespoke injectors, bespoke pistons, bespoke injector pipes.
I'm not sure an exposed FIP drive belt is going to be reliable on a Land Rover either. Are you going to be able to order these easily from Ghana or Kenya or Morrocco to take advantage of its simplicity ?
And with a bit of ingenuity you can stick a 6 speeder behind any engine 😉
Get yourselves a real mechanical engine and dont waste good 300 tdi pumps on your transit engine 😁
Post #784274 31st Jul 2019 9:41pm
HardCharger
Well, one can dream of a mechanical Puma engine that can be used and tuned to equal that or slightly surpass the stock set up of the electric Pumas.
Electrics + water not a good combination Whistle
Post #784476 2nd Aug 2019 5:52am
Oldyellar
Mo
No it's not the di puma injectors work with Bosh pump
Post #784570 2nd Aug 2019 7:34pm
