Home > Tdi > Oil Pressure |
Blackhat90 Member Since: 31 Dec 2016 Location: Forfar Posts: 86 |
Get a presure gauge on it to be shure, ,could be the switch, But,,, Mines sits a 45 psi , cold, ,and its done moon miles,
22nd Jul 2019 11:31pm |
Jeebs Member Since: 23 Oct 2015 Location: North West Posts: 197 |
So I’ve swapped the switch
Old: Click image to enlarge New: Click image to enlarge The new one is a different style to the old one, and I can’t get it to screw in any further than it already has. Is this an issue? Should it be flush like the old one was? Could do with a smaller adjustable spanner as it’s quite tight under there to see if that will help. Oil light is still illuminated for a few seconds on first start up, before flicking off. It doesn’t come back on at all when driving. On second start up it flicks off almost immediately. There are no obvious leaks anywhere bar the sump plug weeping slightly. Any further recommendations? |
28th Jul 2019 2:17pm |
Retroanaconda Member Since: 04 Jan 2012 Location: Scotland Posts: 2555 |
The oil light being on for a few seconds after first starting is quite normal. Every Tdi I’ve driven has done it.
28th Jul 2019 3:53pm |
jfh Member Since: 08 Jan 2014 Location: West Coast Posts: 348 |
I had the same issue, I now use a light duty Locktite (small screws). Works perfectly and the sump plug comes out without a struggle. |
28th Jul 2019 4:35pm |
Mo Murphy Member Since: 01 Jun 2008 Location: Letchworth Garden City, Herts Posts: 2084 |
^^^ what retro said.
Mo The Land Rover 90 - Many are called, few are chosen. |
28th Jul 2019 5:09pm |
I also noticed that the oil filter was slightly loose, so I’ve tightened that up, but it needs a good tightening up tomorrow.
28th Jul 2019 7:54pm |
I've had 2 instances where the oil filter was a quarter turn loose, especially after bad dirt roads.
Now mine is wire locked when I service her. |
28th Jul 2019 8:15pm |
I’ve got my exhaust manifold gasket to do tomorrow, so I’ll give it a good turn while I’m all dirty from that 😄
28th Jul 2019 8:28pm |
