Home > Technical > Oh it's the Defender rattle
Grenadier
Hello all,
Having been watching thoughts on gearbox, diff, transmission, flywheel rattles addendum and finally decided I needed some advice on mine Laughing . As background it is a 2011 2.2 with 60k miles on the clock. The noise is not there when first fired up, but once running is really obvious every time I stop at lights/idle etc. As regards the box, engagement in all gears seems fine, albeit I have to feather the clutch with more skill than Senna to avoid a clunk on engagement.
Have sought opinion locally, but have had three separate answers:
LR Main dealer: No problem, it's a Defender. But I'll tighten the handbrake.
Local do-it-all LR guy: Clutch is on its way out need to change ASAP.
Local, well regarded mech, but who loves/owns a Defender: it the DM Flywheel.
I am at a loss. Big Cry
Can anyone out there in D2.net land give me a final answer. I have uploaded my first ever, most definitely not Ridley Scott, video which hopefully will add some clarity. I have to order parts in the UK and get them shipped over, (cheaper) and don't want to have to do it twice, or more, if I get it wrong. I know this isn't scientific, but any help much appreciate. Thumbs Up
Sorry about the video, was in (smart) work clothes....please go to the end where I depress the clutch. Ta Monsieur Le Grenadier
2011 Puma 110DC - Corris Grey
Post #423468 14th May 2015 12:57pm
Caterham
firstly to ensure you're not wasting your money.......
are they doing any road works at the end of your drive Rolling with laughter
sounds like the clutch to me. doubt it's the hand brake and my understanding is they don't have a dual mass flywheel so I'd rule that out too.
I'm waiting on getting mine replaced - whilst having it done I'm going to bite the bullet and replace the extension shaft (at the very least worth a look while it's apart.
hope you get it sorted.
and with regards to being a master of clutch control to prevent clunk I also know what you mean....for me it's intermittent thou ?
Post #423478 14th May 2015 1:30pm
Re: Oh it's the Defender rattle
Answer 1 is wrong, it isn't normal and it isn't the handbrake (handbrake tends to make a knocking noise as you slow to a halt if tightened too much - it isn't that).
Answer 3 is wrong, because you don't have a dual mass flywheel (the TD5 does, but the TDCi has a traditional single mass flywheel).
It sounds to me like a severe clutch rattle, and I would be dropping the box out as a matter of some urgency to have a look!
If you switch off the engine with the clutch in (engaged, foot off pedal) do you get a short metallic rattle that is absent if you switch off the engine with the clutch out (disengaged, foot pressing pedal to floor)? This is a sure sign of a failing clutch driven plate.
With that degree of rattle on tickover I really wouldn't leave it any longer than I had to to investigate. There is a risk that the springs depart the clutch plate altogether and do significant additional damage.
Post #423485 14th May 2015 2:21pm
Happyoldgit
Assuming you've checked to make sure there's nothing external that's loose and causng it as BW says you'll be needing to get the box dropped asap! Steve.
Ineos Grenadier Trialmaster but owned numerous Land Rover vehicles of all shapes and sizes over the decades.
Current Defender: A non tarts hand-bagged Puma 110 XS USW.. Now long gone.
http://forums.lr4x4.com
Post #423500 14th May 2015 2:53pm
rallysteve
Not sure if the 2.2tdci in the defender has the same issue as the 2.2tdci in fords and jags but the front bottom pulley disintegrates and ruins tge bearing in the aux belt tensioner causing a horrendous rattle at idle. Usually worse by turning the air con on or loading the alternator heavily. Went on my 2.2 xtype and thought it was the dmf!
Post #423524 14th May 2015 3:54pm
Not likely to be affected by pressing the clutch if it was pulley related, I'd have thought.
Post #423533 14th May 2015 4:27pm
LR90XS2011
if its noisy with your foot off the clutch and quieter when you press the clutch it is the clutch rattling, why the box is check the drive shaft to the transfere box, my clutch and drive shaft were u/s at 13k miles even though driven with love DEFENDER 90 TDCI XS,
Post #423539 14th May 2015 4:38pm
Grenadier
Thank you all. Bow down
I thought much the same, having looked at all the forum threads. Will drop the clutch and speak to Ashcroft as a matter or urgency. Thumbs Up Monsieur Le Grenadier
Post #424375 18th May 2015 8:51am
Samfrith
Hi. Read an old thread of yours and wondered if you ever found out what was causing the knocking? I have exactly the same noise/issue with my 2012 90 X -Tech.
Any help or advice appreciated!
Post #780783 9th Jul 2019 9:12am
CharlieDonuts
France 2008 Defender 90 Puma 2.4 SW Galway Green
I had an idle ‘rattle’ coming from the gearbox this week.
It turned out to be the tinplate surrounding the gearbox mount
Half falling off and tapping against the chassis
No idea what this tin plate does
Nor why I have it on one mount but not the other
Post #783178 26th Jul 2019 6:26am
It's a heat shield to protect the rubber mount from the exhaust.
Post #783180 26th Jul 2019 6:49am
CharlieDonuts
Thank you 😊 I’ll put replacing the mounts on the list !
Post #783199 26th Jul 2019 8:58am
Hufflepuff
#you don't need to replace it! Its a free repair Smile
Just bend it so its 'sprung' against the chassis/mount/gearbox, so it can't vibrate.
Its job is to simply to stop the heat from the exhaust cooking the rubber. 2005 Td5 90 XS
1989 V8 110 CSW
Post #783231 26th Jul 2019 12:59pm
CharlieDonuts
Thanks chaps I got underneath at lunchtime and bent it outta the way.
Post #783239 26th Jul 2019 1:33pm
jst
thats quite bad! as ^^^^ drop the box and take a look sooner rather than later.
on the + side makes me less worried about the small rattle mine has! Shocked Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #783323 26th Jul 2019 9:05pm
