Home > In Car Electronics > Kenwood Sub - can’t find the fault
v8bobber
United Kingdom 2008 Defender 110 Puma 2.4 DCPU Java Black
I have a Kenwood KSC SW11 all in one sub / amp thing that has stopped working
The 110 has been in storage for a bit so hasn’t had any use. It needed a battery.charge (which I did off the vehicle) but there is no life in the unit now.
12v supply no probs, fuse ok. Took the unit off, took out the multi plug and 12volts there, earths good. There’s 12volts to the blue / white wire when the head unit is switched on, but the remote (hardwired) remote does not illuminate and obviously no sound out of it.
Any ideas?
Post #782782 23rd Jul 2019 10:22pm
landy andy
Doooh. Just reread yours and trigger/switch live is ok.
Andy
Post #782785 23rd Jul 2019 10:31pm
hank
What happens if you put a 12v remote straight from the battery? Are earths definitely good? > 110 XS Double Cab
Post #782806 24th Jul 2019 6:01am
