Home > Puma (Tdci) > Not starting...help please
pux146
Hello, having a bit of a nightmare! Yesterday drove my landy all day it was fine then it would not start! I had a new starter motor in March! I did a test on the battery and that looked suspect! Then noticed the alternator was on trickle charging! So I thought it was that! I have fitted a new alternator today....and not solved the problem! I can tow start the landy no probs and it drives fine! You can hear the starter motor really struggle to turn like the battery is flat! Is the starter again? I have checked the solenoids under the drivers seat and they are clicking. Any help is appreciate, 2007 2.4 90 fettled & remapped.
Post #782775 23rd Jul 2019 9:54pm
carrotbay
United Kingdom 2008 Defender 110 BMW M57 3.0 Diesel XS CSW Auto Santorini Black
Mine did this last year. I changed the battery and that didn’t fix it. The speed the starter could turn the engine got slower and slower. Eventually it let me down and wouldn’t turn at all. I changed the starter for a new Bosch one and all has been fine since.
Was your last starter a new one? 2008 Defender 110 XS SW - M57N2 / 8HP70X
Post #782809 24th Jul 2019 7:23am
pux146
Hi, yes was a new one or one of these remanufactured the make was Remy 2007 2.4 90 fettled & remapped.
Post #782813 24th Jul 2019 7:38am
skidrov
Australia 2010 Defender 110 Puma 2.4 SW Fuji White
I would suggest checking the ignition switch, i.e. the one at the end of the key barrel. Well known to wear and give strange starting issues.
Post #783012 25th Jul 2019 8:08am
Bluericky
United Kingdom 2009 Defender 110 Puma 2.4 DCPU Keswick Green
What happens when you jump start it ? If it’s good then that would point to the battery . Also once you’ve bump started does it then restart on the key after running a while ?
Otherwise it could be a bad earth , poor battery connection , ignition switch or starter motor .
In my experience with a diesel, when batteries fail they go quite suddenly. My Kawasaki Mule was turning the starter slowly , wouldn’t start unless jumped , changed battery and not been a problem since . Happened overnight
Similar issue with a tractor last year . https://www.instagram.com/hustynminepark/
Post #783024 25th Jul 2019 9:44am
Thon
I'd be tempted to try the earth connections before anything else. 12 year old vehicle (same as mine) is plenty of time for thse underbody connections to get crusty or loose.
Post #783028 25th Jul 2019 10:13am
boxoftricks
United Kingdom 2011 Defender 110 Puma 2.4 USW Zermatt Silver
As mentioned above it sounds like the starter motor is not getting a punchy enough slug of power; earthing points, weak battery, battery terminals. If I were a betting man I think it sounds like a weak connection somewhere.
The second thing I'd look at is ignition barrel. If you change go for a ligit LR one, not aftermarket.
Post #783046 25th Jul 2019 11:47am
pux146
Thanks gents for the all the help, I’ve done a new starter a new alternator and new battery! After the new starter yesterday it started on a jump start! So fitted a new battery today! Gone back to doing the same 🤬 2007 2.4 90 fettled & remapped.
Post #783049 25th Jul 2019 12:20pm
derbywill
England 2005 Defender 90 Td5 XS CSW Java Black
I would check you earth points, I had it with my Td5 and it was the earth from the battery to the transfer box that wanted cleaning up.
When the fault it occuring, try clipping a jump lead from the engine the the negative battery post, this will confirm an earth problem.
Will 2005 90 XS
1954 86'' Series 1 tilt
1968 88” 2A 200tdi
2002 110 Hardtop
Post #783051 25th Jul 2019 12:30pm
pux146
Thanks Will, i shall give that a go. Much appreciated. 2007 2.4 90 fettled & remapped.
Post #783055 25th Jul 2019 1:16pm
Stacey007
Have you tried the relay under the seats?
When mine had it occasional cutting off issues it was the ignition barrel (the bit behind where you insert the key) did you said you have changed this?
Earth straps sounds like another likely cause, Have you had any work lately where these may have been dis-lodged?
Good luck
Post #783056 25th Jul 2019 1:40pm
pux146
Found the fault, i even checked this yesterday with my multimeter! The Negative lead from the battery to the transfer case had a break halfway up! very strange! it was giving me a good reading yesterday. Touch wood its fine now with a new one in place! thanks for the help gents. 2007 2.4 90 fettled & remapped.
Post #783076 25th Jul 2019 3:57pm
