Home > Puma (Tdci) > Knock behind dash
Page 2 of 2 <12
sweatysock
United Kingdom 2007 Defender 110 Puma 2.4 CSW Indus Silver
Roy5695 wrote:
Is your jack/wheel chock or even battery secure in the battery box?
Yip all good in that area, thanks Sweatysock
110 CSW TDCI (Puma) 2007
Post #781902 17th Jul 2019 7:02pm
Roba71
New Zealand 2013 Defender 110 Puma 2.2 XS CSW Orkney Grey
Ive got what sounds like a coin or nut rolling from side to side, when going around corners in the radio area at the moment.
Theres never a dull or quiet moment in a Landy im finding Laughing
Post #781971 18th Jul 2019 12:38am
spudfan
Ireland
I would agree with the bonnet hinge inserts. Lift up your bonnet and if you can move it the inserts are worn. You could drive the vehicle with the bonnet removed and this will confirm for sure if the bonnet hinge bushes are worn. 1982 88" 2.25 diesel
1992 110 200tdi csw -Zikali
2008 110 2.4 tdci csw-Zulu
2011 110 2.4 tdci csw-Masai
Post #782589 22nd Jul 2019 6:11pm
sweatysock
Thanks but already driven with bonnet off....ruled that out Sweatysock
Post #782630 22nd Jul 2019 8:42pm
AndrewS
Check that the bolts holding the floor panels are tight. 130's have feeling's as well you know Smile
Post #782632 22nd Jul 2019 8:48pm
Roba71
I now need to add i've got what sounds like a unmetallic creak coming from the steering wheel area, to go with the coin like noise rolling around the radio area.
I brought this 110 completely creak and rattle free 6 weeks ago, the previous owner must of emptied several cans of "creak free" over the whole vehicle Rolling with laughter
Post #782683 23rd Jul 2019 7:10am
ChrisDefender
Agreed, I tightened up a little bolt that is quite hidden, under the mats and sort of under where the handbrake is IIRC, that cured one of my little rattles!
Def put a bit of lube on the bonet hinge bushes too, that will work.
Post #782696 23rd Jul 2019 10:10am
Front upper damper bushes is possible _\Hennessey|Venom| F5/___
___\⭐️Lone|Star|State/___
____\We|Will|Win/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #782743 23rd Jul 2019 6:06pm
MartyDiBergi
United Kingdom 2016 Defender 110 Puma 2.2 Landmark LE Santorini Black
I have got a creak / knock coming from somewhere in the steering column. It’s only noticeable at low speed on a smooth road and it’s worse when it’s warm. I can feel it through the steering wheel. If I grab the steering wheel and put pressure on it I can make the sound happen but there does not seem to be any play in the column, it’s more like something is rubbing somewhere.
Most bushes have been replaced and the problem is still there. Could it be a sign of a bad steering damper? What is making contact with the steering column behind the dash?
Thanks!
Post #899770 23rd Apr 2021 11:04pm
Scotm
Scotland 2012 Defender 110 Puma 2.2 SW Orkney Grey
If you can't find anything obvious, I would suggest replacing the lower steering shaft. It has three joints in it that can cause a range of noises.
Post #899787 24th Apr 2021 8:18am
MartyDiBergi
Thanks, I will investigate that.
Post #899962 25th Apr 2021 6:31pm
Page 2 of 2 <12
