Home > Puma (Tdci) > Bypass fuel filter? .. stuck on side of road
carrotbay
United Kingdom 2008 Defender 110 BMW M57 3.0 Diesel XS CSW Auto Santorini Black
Hi .. I’ve managed to snap one of the fuel lines off the top of the fuel filter. It got me sufficiently far away from home to be a PITA and I’m now waiting for recovery ( Censored )
Is it possible to bypass the filter temporarily to get it moving ?
Censored it. 2008 Defender 110 XS SW - M57N2 / 8HP70X
Post #782386 21st Jul 2019 4:02pm
dorsetsmith
bypass the filter temporarily to get it moving you cam but any crap in the fuel will end go to fuel pump and VCV
LR009837 fuel filter head part number
Post #782392 21st Jul 2019 4:22pm
carrotbay
Been recovered now on the lorry of shame.
Ordered a new filter housing.
How do these fuel lines come off? Press in the blue bit? 2008 Defender 110 XS SW - M57N2 / 8HP70X
Post #782401 21st Jul 2019 5:01pm
dorsetsmith
Press in the blue bit Thumbs Up
Post #782403 21st Jul 2019 5:08pm
NickMc
these are really common to break on the TDci filter heads, i always blow them out with the air line, then straw on the silicone spray and give it a good blast in around the blue clip and the two "holes' on the bottom of the clip.
Post #782493 22nd Jul 2019 12:56am
Whoever decided to fit the TDCi filter head with plastic spigots really needs a good talking to, it was a really bad idea! As noted above, this is a very common problem.
Post #782507 22nd Jul 2019 8:10am
Rkcorry
I got a pair of these thinking i may never use them , though will say on these type of connectors they really are a god send.
They allow the pipe to be removed without stress of strain on the fitting,
Post #782521 22nd Jul 2019 10:45am
NickMc
They’re for the “bmw” push style and very good I’ve knippex plug boot pliers I use for the same thing, there’s a “slide in” disconnect tool a bit like aircon disconnects for the “Ford” style larger connects Thumbs Up
Post #782588 22nd Jul 2019 6:10pm
HardCharger
Are the pipes on the fuel filter housing plastic? I thought they were metal?
I actually replaced this hose to the fuel tank not too long ago as I kinda suspected that it was a potential air ingress source to my fuel system (it wasn't) and I was thinking of just getting rid of the push fitting then just clamping that sucker down with a traditional hose clamp line the good 'ol days. Will there be a potential issue is this were done?
Post #782676 23rd Jul 2019 2:24am
carrotbay
They’re plastic. I don’t see why you couldn’t go old school and use normal pipe and jubilee clips.
The pipes were difficult to get off as the clips on the main fuel feed pipes were full of dirt and wouldn’t release properly. Had to clean them out and help them off with a small screwdriver.
Fitted the new filter housing and made a siphon pump (thanks to another thread on this forum and Amazon). I cut the ends off the old filter housing to make the right end for the suction pump to connect to the fuel line engine end and got all the air out.
Had a pretty sleepless night on Sunday as she (the Landy) had to be recovered to the public carpark around the back of our house as we couldn’t get her back on our drive. It’s in a very quiet village, but you never know what those thieving Censored will do. Shocked
She’s back in the relative safety of our garden and under cover .. I slept better Very Happy 2008 Defender 110 XS SW - M57N2 / 8HP70X
Post #782684 23rd Jul 2019 7:28am
HardCharger
Glad to know your Landy is safe and sound now.
So I guess I should get some hose clamps (jubilee clips) ready for any future, on demand "upgrades" to the connection. There should still be enough slack in the hoses to pull this off, correct?
Post #782688 23rd Jul 2019 8:40am
