Home > Td5 > Windscreen Wipers & Fuel Gauge (Driving Me Crazy)
RANGER1312
United Kingdom 2001 Defender 90 Td5 CSW Stornoway Grey
Hi all,
Wondering if you can help me with a couple of niggles that are puzzling me...
Firstly the front windscreen wipers won't return to the start position when you turn them off and at the same time there is like a whirring / screeching noise coming from the relay? I've tried replacing the relay for a new one and it's still doing the same?
Secondly I know the td5 fuel gauges are renowned for being irratic and inaccurate but mine is all over the place and when the fuel tank is full the needle on the gauge won't even go up to half way having taken about 3 days to get up to that point?
Any help is greatly appreciated!!
Thanks
Post #782217 20th Jul 2019 11:39am
dorsetsmith
1. windscreen wipers won't return (park switch on wiper motor may be faulty )
2. fuel gauge check wiring both ends i.e. tank and gauge
2.a check gauge go to FSD ground Ci054-2 to battery neg the gauge needle should go to full scale.
2.b IF gauge needle go to full scale you have wiring problem between gauge and tank sender or bad earth , fuel pump sender problem
tank R
E = 326
1/4 = 245
1/2 = 121
3/4 = 63
F = 8
tank plug pin out
4 3
2 1 (2) too fuel gauge (3) fuel gauge sender ground
Post #782225 20th Jul 2019 12:11pm
RANGER1312
Thanks Dorsetsmith!
I have the same whirring noise when the car turns on and also the single swipe by moving the windscreen wiper stalk downwards doesn't work?
Fuel gauge has gradually moved up to the 3/4 mark today but as stated it has taken days getting there (filled it up last week)
Post #782242 20th Jul 2019 4:25pm
RANGER1312
Can you buy the park switch separately or is it built into the motor or motor itself?
Post #782444 21st Jul 2019 7:04pm
grafty99
The park switch is replaceable on its own Thumbs Up 2002 90 Td5 Station Wagon
1990 Vogue SE
Triumph Tiger Explorer 1200
Post #782446 21st Jul 2019 7:20pm
RANGER1312
Thanks Grafty!
Don't suppose you have a part number for it? Figure your 90 looks like you've had nearly all of it apart over the years Very Happy
Post #782463 21st Jul 2019 9:09pm
dorsetsmith
LR057182 snap
Post #782464 21st Jul 2019 9:15pm
landy andy
Post #782465 21st Jul 2019 9:15pm
grafty99
As above, I have indeed replaced it, although now running a custom motor with solid link bars and pivots like modern wiper systems. Much less to go wrong Rolling with laughter 2002 90 Td5 Station Wagon
1990 Vogue SE
Post #782469 21st Jul 2019 9:52pm
geobloke
Oooo think we need details Grafty...!
If you are going "in" to do the parking switch you might as well just go the whole hog and replace the wiper wheel boxes and push cable as well. Makes a huge difference if your wipers are a bit wayward...
And of course since you have the dash out you might as well either fit a second washer nozzle or one of the superb Optimill nozzles and high power pump systems (with ever penny...), then there are heated mirrors and why not fit the wiring for a Madman gauge... Rolling Eyes Whistle
Post #782534 22nd Jul 2019 12:10pm
RANGER1312
Thanks for the part number guys Thumbs Up
Grafty I wouldn't mind learning more details about the parts you used and how you did it Thumbs Up
Geobloke is the wiper wheel boxes and push cable a big job or costly job?
Post #782652 22nd Jul 2019 9:47pm
RANGER1312
I know that some OEM parts can be just as good as genuine, I personally have never had a problem with some brands but in relation to the park switch do the aftermarket ones work well or is genuine LR the way to go?
Bearmach and Allmakes are around the £10 price point vs £25 for genuine?
Post #782780 23rd Jul 2019 10:17pm
4RF RDS
Canada 2000 Defender 110 Td5 XS CSW Epsom Green
In my experience, OEM is fine in this case Thumbs Up 2010 Range Rover MkIII Autobiography Super Charged (Idris)
2003 Range Rover Mk III (Desmond FitzWilliam)
2000 Defender 110 CSW TD5 (CTX)
1992 Range Rover Classic (Lizzy)
1972 Series III 300 Tdi (Stanwood)
1967 MGB GT
Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats.
H. L. Mencken (1880 - 1956)
Post #782801 24th Jul 2019 1:58am
geobloke
Not really. Takes a little bit to get the dash top off and centre dash panel out enough to work, mostly cross head screws. The hardest part is the fitting of the wheel boxes as you really need a second person to hold it in position whilst you do up the nut. Apart from that it is a worthwhile job.
Oh and do not forget that this is a great time to do the DefenderVent mod too... Rolling Eyes Whistle
Post #782819 24th Jul 2019 8:14am
geobloke
Agree. I have OEM and they have been in for 6 years with no problem.
Post #782820 24th Jul 2019 8:15am
