Home > Maintenance & Modifications > Tips on fixing galvanic corrosion
mattc
United Kingdom 2005 Defender 90 2.5 TD HT Java Black
My 90 has got some galvanic corrosion around some of the rivets and under the body cappings, plus a bit of rust forming on the frame at the rear. Please could anyone give me an indication of the work required to sort this? Looking to take it to somewhere in the North West/North Wales area if possible.
Many thanks!
Post #781927 17th Jul 2019 8:28pm
90 Dreamer
Looks pretty poor, what age is the truck if you dont mind me asking??
Post #781933 17th Jul 2019 8:46pm
mattc
It's a 2005. The rest of it is in quite decent shape, so keen to get this sorted to tidy it up and prolong its lifespan.
Post #781934 17th Jul 2019 8:47pm
Oldowner
The body is only in primer at best behind the cappings. So to do properly you need to remove the cappings and have them shot blasted and hot zinc sprayed, and whilst that is being done paint the unpainted portions of the body which were hidden by the cappings.
Post #781938 17th Jul 2019 8:59pm
CharlieDonuts
France 2008 Defender 90 Puma 2.4 SW Galway Green
I have the same issue on my rain gutters and around the quarter lights. I want to clean it up before fitting a roof tent. Do I clean it back to bare metal, prime with a zinc primer and respray. I only wash the 90 once a year and I will respray the roof matt black. So it needs to be done as to not come back but I don’t need a fancy paint job.
Post #781988 18th Jul 2019 9:17am
boxoftricks
United Kingdom 2011 Defender 110 Puma 2.4 USW Zermatt Silver
Back to bare metal, zinc primer and then paint is how the bodyshop would do it. You may like to use a high build primer between the zinc and paint. Build up a few coats to knock back to get a nice smooth finish.
Post #782008 18th Jul 2019 12:04pm
Green Machine
As oldowner says, the only way to properly resolve it is to lift the roof / body sides off the tub and then drill out the rivets and remove the cappings.
I went through this exact process on my 2005 90 with a local bodyshop a couple of years ago. Replaced the tub cappings, the rear corner cappings and the lamp panels. Mine were all pretty far gone to be honest, so I replaced all with new. The key is to make sure everything is fully painted before reassembly - doing as much as possible to make sure there is a good separating layer of paint between all the elements. I then got the bodyshop to seal the edges of the cappings with black automotive sealant, which hopefully prevents any water getting in behind there. They also ran a bead of black sealant along the top of the cappings in the gap between the body side and the top edge of the capping.
There is an argument to replace with galvanised cappings (or have your existing cappings galvanised if they're good enough). In the end I decided against this as I was advised that the paint finish on galvanising would never be as good as on bare metal (no matter what the prep) and there was a risk of the cappings warping when galvanised and not fitting properly. But you can always use a zinc-rich primer as a compromise.
Like anything with paintwork it all comes down to the thoroughness of the individual who actually does it! I haven't been totally impressed with the work I had done - it is already starting to show the early signs of corrosion again around the rear corner cappings. But mine doesn't get cleaned very often and is used through the winter with the huge amount of salt we get on the roads round here. It's also parked outside and not garaged. So the odds are stacked against it from a corrosion point of view!
Final point is to used sealed / closed rivets in re-fitting everything, so water can't track through the rivet itself. Basically seal and isolate everything as much as possible!
Good luck! Thumbs Up 2005 Td5 | 90 Station Wagon | Tonga Green
Post #782010 18th Jul 2019 1:10pm
mattc
That's really useful to know. Thanks everyone. Definitely beyond my skills so I'll be looking to find a specialist to tackle it for me. Can anyone recommend anyone in Cheshire or surrounding counties, please?
Post #782011 18th Jul 2019 1:19pm
Oldowner
If you have them hot zinc sprayed it is pretty much as good as galvanising and none of the above issues. I have a series bulkhead I had hot zinc sprayed in early 2000s and no rust on it despite it being parked 10m from the sea.
Post #782027 18th Jul 2019 6:34pm
Scotm
Scotland 2012 Defender 110 Puma 2.2 SW Orkney Grey
If you get all the parts sprayed it isn't a difficult job to do yourself. Just a little time consuming. I did my previous 110 myself on the drive.
Post #782059 18th Jul 2019 10:48pm
roel
Corrosion on the alu panels has to be removed completely otherwise it comes back very soon.
My 2003 90 started life as a farmers pick-up, the advantage off that is that the cappings are galvanised and painted not just painted.
I took the paint off as I like the old style look.
 Roel
2003 90 Td5 (2009-now)
Post #782080 19th Jul 2019 12:32pm
CharlieDonuts
Frankly only a Land Rover owner could take a photo like this. The ingenuity alone !
My mechanic mate's, best mate, who is the guvnor at the local body shop, says he can clean, prime and blow my roof in matt black for 350 euros, just have to wait for the summer holidays to be over. Good'o.
Post #782228 20th Jul 2019 12:38pm
mattc
As this work is a significant step above my skills, I've been looking for a specialist. I have to admit, I haven't a clue what sort of price is reasonable, but was surprised at the first quote received. This was to replace the RHS tub capping, replace the rear quarter cappings, tidy a couple of dents and then spray it all black.
Quote:
1,Repair and paint roof panel above the rear door
2,Paint to rear door
3,Repair and paint dent in door, to blend into front wing
4,Repair and paint o/s rear quarter where capping has been removed and blend into panel
5,Repair and paint n/s rear quarter where capping has been removed and blend into panel
6,Paint rear tub panels o/s & n/s where capping has been replaced and blend into panel
7,Paint to new cappings
8,Remove and refit roof panel and o/s & n/s tub panels to replace cappings
Total labour, Paint and materials £2870.64
Total Parts ( cappings x 4 ) £336.28
Sub total £3206.92
VAT @ 20% £641.39
Total £3848.31
Obviously, removing the roof and sides is a fair bit of work! Any suggestions on who to try for a cheaper quote, or advice on whether this is realistic, please?
Thanks!
Post #782564 22nd Jul 2019 2:36pm
JOW240725
If you were closer to Suffolk/Essex I'd highly recommend Hangar 53 for this sort of work. There is CSK in Hoddeston. But in your area I would recommend having a look at Carriages Auto Services Ltd, Manchester or 4x4 Fabrications, Wrexham? James
Instagram @suffolk_rovers
Post #782571 22nd Jul 2019 3:53pm
mattc
Many thanks, James! I'll give them a try.
Post #782572 22nd Jul 2019 3:54pm
