Home > Maintenance & Modifications > Dash illumination
Stiff1
Dash illumination
So while covered a length elseware I thought I would rekindle the idea.
While the centre console was out this evening on the Puma I thought I would investigate the poor illumination around the heating controls and other switches.
Indeed a couple of the bulbs had gone, including the one in the lighter. Swaped a working one into the lighter and all illuminated so thats sorted.
The headlight leveler also does not light up but can not see an obvious way to get into it, is it a changable bulb or do you have to replace the whole switch?
Also what is the feeling on moving over to LED? Don't want to change the colour or anything like that but would like them a little brighter. However not keen on the very cold white light from some LED's
I think the present filiment bulbe are 1.2W and I see 2W are available as here
https://www.ebay.co.uk/itm/Land-Rover-Defe...SwASRceBd1
Post #781813 17th Jul 2019 12:30am
zippo87
Scotland 1996 Defender 110 300 Tdi CSW Epsom Green
Whilst I don’t have your answers - as puma is way too flashy for me 😆. I used https://www.classiccarleds.co.uk (no affiliation)on my 300 and have never been disappointed - I do believe they also offers LEDs in different brightness levels.
I’ve changed to led for sidelights, dash, and interior lamps, and it makes a considerable difference - especially when I’ve got the family in the back munching on fish and chips in the winter!
Post #781816 17th Jul 2019 3:47am
Another option is to fit a RRC dipping mirror with map lights
These are getting rare now, they have the adjustable dipping slider switch and 2 map lights that light up the dash area but don’t affect the drivers sight
I may have one tucked away in the garage
Post #781821 17th Jul 2019 6:15am
Roy5695
The headlight adjust has an led on the inside. This can be cut out and a new one soldered in if you were inclined to do so.
 2011 Defender DCPU 2.2 - https://www.defender2.net/forum/topic30623.html
Instagram - @r22oyp
Roy
Post #781845 17th Jul 2019 10:32am
Stiff1
Thanks Roy, like the illuminated cup holders.
Would like to see more about the mirror, have been concidering an auto dim one. I have a suction cup stick on one fixed to the very top of the windscreen as cant stand the original right in my line of sight.
Post #781847 17th Jul 2019 11:22am
Defendermatt
United Kingdom 1989 Defender 90 Other SW Bonatti Grey
Roy, any info on changing the instrument cluster backlight colour? Very Happy
Post #781850 17th Jul 2019 11:24am
Roy5695
About 20 surface mount LEDs need to be de-soldered then new SMDs soldered in place. Obviously after fully dismantling the clocks. 2011 Defender DCPU 2.2 - https://www.defender2.net/forum/topic30623.html
Instagram - @r22oyp
Roy
Post #781858 17th Jul 2019 12:47pm
Roy5695
Matches my doors 😎
Instagram - @r22oyp
Roy
Post #781964 17th Jul 2019 10:39pm
