![]() | Home > Maintenance & Modifications > Fire extinguisher mount points - share yours thnx! |
| Zed Member Since: 07 Oct 2017 Location: In the woods Posts: 3362
Giving this old thread a bump as I'd like to mount a fire extinguisher.
More ideas and photos would be appreciated. |
| Bluest Member Since: 23 Apr 2016 Location: Lancashire Posts: 4341
If you've got some money (unlike me 😁), consider a halon extinguisher. Make much less mess in the event you have to use it. 2007 110 TDCi Station Wagon XS
| 90 Dreamer Member Since: 13 Jul 2019 Location: Oop North Posts: 2308
Pretty sure you will find that Halon has been technically illegal for years except for certain uses (Aircraft, etc.) so you may struggle to even find one.......
| dorsetsmith Member Since: 30 Oct 2011 Location: South West Posts: 4554 |
The EU ban on the use of Halon in fire extinguishers actually came into force in October 2000 and was implemented in the UK in 2003, as a result of scientific research linking Halon and other CFC’s to Ozone depletion. The ban in practice is not total.
dry powder for class ABC fires |
Only problem is powder can get compacted over time when carried in a vehicle
Ok, no Halon, what am I thinking of then? When I was in a car club around ten years ago everyone was into these extinguishers that didn’t make a mess. Could have sworn it was halon. 2007 110 TDCi Station Wagon XS
Quite possibly but very difficult to get hold of without a legitimate reason or some very 'good' connections.......
| LandRoverAnorak Member Since: 17 Jul 2011 Location: Surrey Posts: 11327
I've just noticed that I contributed to this thread nearly three years ago, when I had a different vehicle! On my current 110 USW, I've made use of the dead space in the trim for the non-existent window on the hinge-side of the rear door. I made some brackets from ali channel that bolt to the top and bottom of the side panel, behind the trim:
Click image to enlarge Click image to enlarge Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
| All times are GMT |
