![]() | Home > Maintenance & Modifications > Defender 2007 indicator problem |
mick Member Since: 08 Feb 2010 Location: Yorkshire Posts: 2109 ![]() ![]() ![]() |
Probably a bad earth
boardstein Member Since: 13 Jul 2019 Location: leicestershire Posts: 10 ![]() ![]() |
Thank you Mick, how can i check this?
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20916 ![]() ![]() |
Likely an earth as mentioned. I would check the earths on the transfer box. Remove, clean, replace, protect.
Before you do that though if you have one or access to use a multimeter to check continuity on the earth side and for voltage on the live side. Was this LED or Standard (Incandescent light bulbs.) ____\We|Will|Win/___ ____/π¬π§πΊπΈ\____ _//*β½οΈπ’οΈβοΈπ§°*\\_ |
grafty99 Member Since: 15 Aug 2012 Location: North Devon Posts: 4802 ![]() ![]() ![]() |
I would say corrosion in the bulb holder. 2002 90 Td5 Station Wagon
Steve and Grafty thank you, they are std bulbs, so it sounds like the earth - thank you for your help
