Home > In Car Electronics > New 'virgin' audio install & speakers in lower dash... |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 19533 |
What is your alternator input may I ask? Diesels Lives Matter. ⛽️🛢️👨🔧🧰⚙️
And if You Love the Country, then we’re on the same side ~ I got’ love for Britain, I got’ British pride’. 🇬🇧 |
8th Jul 2019 4:45pm |
northernerindevon Member Since: 28 Feb 2018 Location: Bristol Posts: 58 |
Its a 12v vehicle with a retrofitted 300TDi - I have never upgraded the alternator so presumably a 60amp one.
8th Jul 2019 4:52pm |
You really need to find the output really if you can.
Do you know your amplifier Wattage RMS for all channels? Diesels Lives Matter. ⛽️🛢️👨🔧🧰⚙️ And if You Love the Country, then we’re on the same side ~ I got’ love for Britain, I got’ British pride’. 🇬🇧 |
8th Jul 2019 4:57pm |
Hi Steve,
No, not at this time; I haven't got as far as choosing all the equipment. What should I be looking for regards the amplifer wattage RMS? Cheers, Paul |
8th Jul 2019 5:12pm |
Well it depends on what you are looking to fit power wise, but what ever you do fit would need to be lower current draw than your alternator output. 60A is fairly low as you have to take into account other ancillaries and HU current draw off as well.
Have you considered an upgrade alternator or for a TDI there maybe a twin set up a available. From there you can the do ‘the big three’ upgrade which includes upgrading your ground, and alternator to battery feeds etc. It really depends on what wattage equipment you want really. The more power the higher cost and upgrade but you get more power and sound quality for your money. Finally if you upgrade to fitting tweeters, I’d recommend 1” the same as Puma’s. (If there is room?) And when drilling use a cone cutter not a hole saw. They are much safer, accurate, cleaner cut and will keep a more concentric hole. Obviously check everything is clear behind. You may have planned to do this anyway. Diesels Lives Matter. ⛽️🛢️👨🔧🧰⚙️ And if You Love the Country, then we’re on the same side ~ I got’ love for Britain, I got’ British pride’. 🇬🇧 |
8th Jul 2019 5:33pm |
Hi,
Thanks for the reply. I'm not looking for a crazy powerful expensive system but ref. the alternator - food for thought & something I hadn't considered. Good call on using a cone cutter rather than a hole saw. Cheers, Paul |
8th Jul 2019 6:15pm |
JOW240725 Member Since: 04 May 2015 Location: Suffolk Posts: 7873 |
I believe FCX are still selling their cubby, I'm sure they were advertising them recently.
I have the Far Corners sub under chubby box, very pleased with it. Has space for extra switches, usb sockets on front which is useful. Haven't got pics on mobile but they're on my thread. James MY2012 110 2.2TDCi XS SW Orkney Grey - http://www.defender2.net/forum/topic43410.html MY1990 110 200TDi SW beautifully faded Portofino Red - https://www.defender2.net/forum/post743641.html#743641 MY1984 90 V8 Slate Grey - https://www.defender2.net/forum/post744557.html#744557 Instagram @suffolk_rovers |
8th Jul 2019 9:17pm |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 7682 |
You can fit a 100a alt in std place on a 300tdi. Is std not 85a anyway? I would of thought std alt even at 60a more than capable unless you going to blow your ear drums Cheers
James 110 XS Utility 130 Puma Station wagon/camper (in the making) 90 Puma Hardtop |
8th Jul 2019 9:44pm |
Yeah, the TDI’s are typically around that range for output. The trouble you can get is fluctuating voltage under load, dimming of headlights etc.
Mind you class D Amplifiers are a lot more efficient, but you’d be surprised how much juice they can pull. Just depends on what wattage really. 400wrms should be okay, but that is not including to many extras. 800wrms is nearly the capacity of the alternator at 12.2v but charging voltage does bring the load down. So long as the load doesn’t exceed the output of the alternator giving some room for charging current then there isn’t a problem. Worth checking the battery and the charging voltage for stability though.👍🏻 Diesels Lives Matter. ⛽️🛢️👨🔧🧰⚙️ And if You Love the Country, then we’re on the same side ~ I got’ love for Britain, I got’ British pride’. 🇬🇧 |
8th Jul 2019 10:46pm |
I've been in touch with Mitch at FCX recently & they are indeed still selling the cubby box - its just currently out of stock. Has anyone got one that can comment on it?
JOW240725 - cheers for your comments about the Far Corners sub locker. Just off to have a look at your thread! I think my standard alternator will be fine - as I alluded I don't (think) I want a crazy system but, nearer the time, I'll maybe post up kit I am thinking of and you can critique it for me. Cheers for the replies so far, Paul |
8th Jul 2019 10:53pm |
V8Simon Member Since: 17 May 2016 Location: Prestatyn, Wales Posts: 137 |
I had speakers in the front lower dash as you mention. Its where they were fitted by a professional company many years ago and were fine although on their own might be a bit weedy in a noisy LR so I'd definitely include the other ones in the rear.
Agree about the headlining being a little too close to your head but I think there's a pic in this months LRO of someone who has that. From memory, there's a metal skin behind the soft bit in the lower dash. I have my old dash, i can have a look if required as I took the speakers out? 1984 90 V8 puma want to be. |
11th Jul 2019 11:53am |
V8Simon,
If you could have a look for me that would be great. If you could get some pictures that would be even better! As its a fresh install I intend to fit 13cm speakers under the dash instead of the standard 10cm (assuming there is space) along with 1" tweets on top of the dash along with 16.5cm ones in the MUD rear panels (these will need trimming I know) Thanks again |
11th Jul 2019 12:15pm |
This is the drivers side but you can see the metal skin behind. Its short work with a jigsaw though. Don't forget you'll need a spacer for the passenger side speaker in this position as otherwise it fouls the wiper motor. Sorry, I could'nt see the passenger side dash as I removed it from the bulkhead when replacing the bulkhead.
Phones are side on for some reason. Click image to enlarge Click image to enlarge Regards Simon 1984 90 V8 puma want to be. |
11th Jul 2019 12:51pm |
Those are ideal V8Simon, many thanks for those.
Cheers! |
11th Jul 2019 2:17pm |
