Home > Technical > Pumas in hot climates
Bluest
We've been doing a spot of overlanding of late and were caught in the heatwave in northern Spain a week or so ago. On a few days the temperature was heading to 45c. During this heat the defender suffered power loss a few times climbing mountain passes. No warning lights or movement of the temp gauge though. Power would come back after a few seconds. Lots of 2nd and 3rd gear uphill hairpins seemed to be the trigger. I seemed to be able to avoid the issue if I stuck in a lower gear and revved the engine a bit more.
Is the 2.4 cooling system marginal in these conditions, or could it be a different issue? I'm thinking that by revving more the fan was doing a bit more to keep the temp down. Car was loaded with stuff but not extremely so.
Be in interested in the thoughts of anybody else who lives in warm mountainous climates. 2007 110 TDCi Station Wagon XS
Post #780948 10th Jul 2019 12:26pm
Eduardo
Bluest,
It's a looong history cover in this forum several times.
In fact, the Defender cooling system appears to be very tight. A lot of people refering to this problem in special under high temps (over 35°C). high speed in 6th gear under mild slopes and medium/high load.
Mine suffered this issue almost all summers since 9 years.
Probably you are suffering the same but more acute due the high slopes.
Some actions to avoid the problem:
1) Change the termostat for one that opens at lower temperature
2) use the nakatenga extension for the fan
3) Upgrade intercooler
4) Upgrade the radiator
In fact, if you slow the gear the problem disspeared.
Cheers! Eduardo
Post #780982 10th Jul 2019 3:56pm
EastFreo
Australia
I have a 2.2 Puma and to date have had no issues in what can sometimes be very hot Western Australia (ie regularly over 40c in summer). Not exactly mountainous though.
Post #780989 10th Jul 2019 4:43pm
Bluest
Interesting, topic. A combination of high temps, high load and low fan speed and low water pump speed maybe.
I'll mull it over, but a better intercooler and radiator are probably the best fix. Fortunately, these conditions are rare for an Englishman to encounter.
I was pondering the the fan spacer, but I'm not convinced it would help. I used to work as a draughtsman for an industrial fan manufacturer and axial flow fans always had the impeller half shrouded, which is how the Defender is as standard. Fully enclosing the blades in the shroud should not improve its performance from what I know. 2007 110 TDCi Station Wagon XS
Post #780997 10th Jul 2019 6:45pm
Eduardo
My approach was start from the cheaper to the most expensive.
I started with the nakatenga spacer. Temperature showns an slight reduction (maybe 1-2°C) but still not solve the issue)
Then the thermostat probably help something (1-2°C extra) but not make the difference.
Finally the uprated radiator do the trick and the temperature drops enough to be under 115°C in all the way (If I remember the engine cuts at 120°)
Cheers! Eduardo
Post #781007 10th Jul 2019 7:42pm
Bluest
Which radiator did you choose? 2007 110 TDCi Station Wagon XS
Post #781013 10th Jul 2019 8:13pm
Pickles
We never had any issues with our 90 in 40C heat. However, mountainous roads were not involved, pretty flat country, sitting on around 100kph but the air cond was on obviously, which can put more load on the cooling system, but the temp gauge never moved.
Pickles.
Post #781042 11th Jul 2019 12:25am
HardCharger
Will adding an aux fan, making them two upfront, help? Not only will it help the AC keep cooler, it may help the engine with the increased pull of air in. At least that's what I'm thinking.
Currently being in a tropical country, the temps are starting to reach 45 degrees celsius every now and then. We also have mountain roads and steep inclines to deal with so I'm watching this thread to ensure my truck operates in the optimal range.
I remember a discussion on different thermostats here somewhere so there is merit to it. As for uprated radiator, Allisport makes one, I think? For the uprated intercooler, there are a few manufacturers already mentioned in this group.
Post #781046 11th Jul 2019 2:23am
Bluest
The thing with running a different thermostat is that it has no effect on the capacity of the cooling system. Yes, the engine may run a little cooler in normal conditions, butonce the the limit of the system is reached and the thermostat is fully open you'll be in exactly the same situation as with the standard one.
A bigger radiator is the only proper fix I can see really.
Incidentally, those high heats mine ran fine at highway speeds (100-110 kph) even up some reasonable gradients. Also I did a fair bit of low range trails on very steep mountain passes, again no problem. It was the tarmac mountain switchbacks that did for me. 2007 110 TDCi Station Wagon XS
Post #781060 11th Jul 2019 8:34am
Eduardo
Allisport... Eduardo
Post #781158 11th Jul 2019 7:06pm
Eduardo
Pickles.
At 100 kph is not an issue. The issue appears when the speed is 120 kph in 6th gear in mild slopes for a long time. Eduardo
Post #781159 11th Jul 2019 7:13pm
ericvv
Eduardo, was the installation of the Allisport radiator really plug ‘n play? Or did you have to cut away and adapt certain things on the truck to make it fit? Allisport on their website say it’s a straight fit, but a customer review talks about having to cut away some plastic parts....
Interested, as one day I may want to install such a bigger radiator to further improve cooling.
http://youtu.be/yVRlSsJwD0o
https://youtu.be/vmPr3oTHndg
https://vimeo.com/201482507
Post #781199 12th Jul 2019 5:30am
Eduardo
Eric
Was almost Plug & play. Not cutting or mods needed.
Only the radiator upper cowl were located a little bit higher after the mod, but doesnt interfer with the bonnet closing.
Cheers! Eduardo
Post #781240 12th Jul 2019 2:46pm
