![]() | Home > Off Topic > Supplier of end of life taps |
gilarion Member Since: 05 Dec 2013 Location: Wales Posts: 5130 ![]() ![]() ![]() |
If they are the same as these
![]() Then http://www.vitra.nationwide-bathrooms.co.u...-taps.html have them n stock you may be able to bend their ear to sell you one For those who like Welsh Mountains and narrow boats have a look at my videos and photos at.. http://www.youtube.com/user/conwy1 |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5979 ![]() ![]() |
Drill through back of tap head and either tap a thread then use a grub screw or drill tap head and spindle, then insert pin through both would be alternative options.
excossack Member Since: 22 Feb 2012 Location: North West Posts: 6008 ![]() ![]() ![]() |
Them the ones - thanks. I have emailed them 1999 Defender TD5 110
That is a plan I have thought of, and may come to that if I can't get tap handles. 1999 Defender TD5 110 Regards John M0VAZ Econet Station 48 no clock |
Called the people nationwide bathrooms and no joy. Not available.
![]() Regards John M0VAZ Econet Station 48 no clock |
the gamekeeper Member Since: 01 Jan 2010 Location: Surrey Posts: 97 ![]() ![]() ![]() |
Is it the tap head or spindle, as screwfix have replacement inserts if its the spindle that has given up
Its the splines in the tap head that have worn 1999 Defender TD5 110
hank Member Since: 12 Sep 2016 Location: South Wales Posts: 2347 ![]() ![]() ![]() |
Cheers. Had checked ebay a few times an none available. Now purchased.
![]() ![]() ![]() ![]() Regards John M0VAZ Econet Station 48 no clock |
For info they are ARES not ARIES, maybe this was effecting your search results > 110 XS Double Cab
That might have been part of it
Glad you got sorted though
Hopefully so. £49 for just the handle is better than having to spend on replacing taps and then having to squeeze under the bath and double bend myself! 1999 Defender TD5 110
Turns a painful few hours into a five minute job touch wood! Plus you have spares for the future > 110 XS Double Cab
