Home > Technical > key fobs vs. integral key.
landybehr
Hi,
I need to get new key fobs for my Defender. No Problem so far.
Now I have seen that there are keys with integral remote control around. Just like on recent Discoveries and Range Rovers.
May be that there is even such a kind of key for the very last year(s) of the Defender.
Obviously a Diagnostic Tool that is used to assign the key fobs to the AS10 does not care for how they look like. They heave to be 433MHz, ok.
Is there a realistic chance to program new integral keys to my Defender, just like to be done with the former key fobs?
Post #779898 2nd Jul 2019 2:51pm
bankz5152
You can buy kits off ebay that give you an L322 style fob and uses the internals of your current fob. However you need to find s key place that will cut it for you. I couldnt find one that would cut a key i supplied.
Post #779901 2nd Jul 2019 2:55pm
Sulisuli
Isn’t there a forum member who sells these key fobs or is my old memory playing tricks again. Someone will remember a name and post it before I can remember I’m sure. 2015 HT XS 90
2008 SVX 90
2000 XS TD5 90
Post #779914 2nd Jul 2019 3:47pm
landybehr
I found the "transplant the guts into a new shell" option, but somehow it seems that the 2.2 Tdci is exempt from that. Some parts dealers / internet dealers offered a "send me key and key fob, and get them back merged together", but I cannot see this for my Defender.
A professional key service answered me, I could only carry on with the standard key fob as long as the 2.2puma is concerned. But they may not be very deep in LR matters.
Post #779942 2nd Jul 2019 6:41pm
Harry.O
United Kingdom 1989 Defender 90 300 Tdi ST Nato Green
https://remotekey.co.uk/land-rover/defender-2/#defenderallinone Thumbs Up 2005 Td5 110 Hardtop
1989 300Tdi 90 Soft top
1992 200Tdi 90 Truck cab with Land Cruiser axles
Post #779982 3rd Jul 2019 5:36am
hank
I was interested in this also but progress stalled on it. There are a couple of threads below.
I am working away at the moment in Riyadh, where there are hundreds of car key programming shops, I intend to bring my Defender key fob & key over with me and see what they can do. I will report back but it is likely to be after August
https://www.defender2.net/forum/topic56343.html
https://www.defender2.net/forum/topic55695.html > 110 XS Double Cab
Post #779986 3rd Jul 2019 6:26am
landybehr
Hi,
@HarryO. I followed that link and again ... : "This will work on all Defender models to 2012".
Why is it that the 2.2 cannot have what is no problem with the 2.4 Puma and predecessors?
I once came across that site/page:
https://www.autoschlusselshop.de/landrover...amp;page=3
This one is offered as applicable to Land Rover Defender (Chassis EA000001- with remote locking) -2014 -2016
And while a Defender of 2014 to 2016 is just as much a 2.2Puma, as the 2012 to 2014 ...
What makes the difference between the ModelYears ?
[/img]
Post #780080 3rd Jul 2019 10:53pm
Harry.O
I'm afraid I can't help you with that, I was looking at it for a TD5, perhaps there is a difference with the ignition barrel or the cowl though.
Whilst I have no reason to distrust this company, my one reservation is that you are providing them your address for the postage and later your EKA code when you return the box. As an alternative, you could buy a blank all-in-one key and programme it with a Nanocom or similar? 2005 Td5 110 Hardtop
Post #780102 4th Jul 2019 8:32am
Montblanc
France 2007 Defender 110 Puma 2.4 XS CSW Zermatt Silver
I just bought a new case for the remote for my '07 110 xs sw. The land rover packet says refer to Land Rover technical bulletin No.86-12-96. Anybody have a copy of that bulletin or know what it says?
Post #782561 22nd Jul 2019 2:15pm
hank
If your old fob still works and you are just replacing the case for aesthetic reasons, then just take the circuit board out of the old case and place it into the new case.
If it's a flat battery re-sync then see here https://www.defender2.net/forum/topic13844.html
If it needs programming then you need software and I can't help you > 110 XS Double Cab
Post #782565 22nd Jul 2019 2:52pm
HardCharger
landybehr wrote:
Hi,
[/img]
From what I know, the 2.4 Pumas and a few of the 2.2s have the 10AS module for their security and this is what most of these key alternatives work with.
The later Pumas have moved away from the 10AS and are now using a different module, color black rather than green, if memory serves and this is why the older key alternatives will not work.
Actually, there has been talk that some dealers will tell you that you can no longer get the 10AS module (should you need it) and you must upgrade to the newer modules. Not sure how true this is but there are still 10AS modules out there so you won't really have to upgrade the module until these supplies run out.
I'm not sure if there any significant differences between the 10AS and the black module so if anyone out there knows, please do enlighten us. Thumbs Up
Post #782677 23rd Jul 2019 2:37am
Montblanc
Cheers Hank
Just changing the case as the rubber has worn through. I'll probably put a new battery in as its been a couple of years since I last changed it as per the workshop manual.
Just wondered what the bulletin was all about.
Post #782821 24th Jul 2019 8:19am
