Home > Puma (Tdci) > For those with MY2009 Pumas: Service Action Number Q055
Eduardo
This Service action appeared wome weeks ago:
Quote:
Subject:
‘A’ Frame Suspension Arm
Publication No.: 204-Q055
Model: Defender
Model Year: 2009
VIN Range: LD771715 – LD772545
Date of Issue: 03 February 2009
Expiry Date: 28 February 2011
RE: ‘A’ Frame Suspension Arm
Dear Colleagues
In plant quality inspections have determined that on a number of 2009MY Defender vehicles, the
'A' frame top link arm bushes at the chassis bracket location end of the arm can rotate due to a
potential ovality/oversize of the bore in which the bush is installed.
Customers may experience vibration and a noise likely to be a whine.
Action to be taken
At the next service opportunity you are requested to visually inspect and repair if necessary. The
workshop procedure is attached as Appendix 1.
Please ensure all unsold vehicles are repaired prior to handover to the customer.
A number of vehicles have been reworked at the factory prior to dispatch and can be
identified by a white square sticker in the corner of the windshield; no further action is
required on these vehicles.
Please check DDW to ensure that the vehicle is affected by this Service Action prior to
undertaking any rework action. DDW will be updated to reflect only those vehicles
affected. Should you require a listing of the affected vehicles, please contact the Land
Rover Field Actions team by e-mail at jlrcamp@jaguarlandrover.com. All overseas
requests should be forwarded via the National Sales Company/Regional Office only.
At the time of confirming a booking for vehicle repair, please ensure that all
outstanding Field Service Actions are identified to ensure the correct parts are
available and adequate workshop time is allocated for repairs to be completed at one visit
The Service action is in PDF. If somebody need it, please do not hesitate in contact me by PM.
Cheers! Eduardo
Post #7768 25th Feb 2009 11:38pm
Scallops
Australia
Pity that doesn't apply to 07 MY vehicles - because I have the issue and can't for the life of me find the source.
Post #7769 26th Feb 2009 2:42am
one_iota
Australia 2008 Defender 110 Puma 2.4 SW Alpine White
Could this be yours?
http://forums.lr4x4.com/index.php?showtopic=27251&hl Mahn
'08 Defender 110
ex '95 Disco 300 Tdi
www.aulro.com
Post #7774 26th Feb 2009 10:21am
solmanic
Australia 2007 Defender 110 Puma 2.4 XS CSW Stornoway Grey
From memory, I read somewhere that the really early 07MY Defenders still had the bolted A-frame brackets. There is a posting somewhere that lists the serial numbers which are affected by that TSB you linked. 2007 Defender 110
1970 Alfa Romeo 1750GTV
Post #7801 27th Feb 2009 12:09am
Scallops
Australia
Thanks guys - Scallops here - mine is in the VIN range but my A frame is bolted - I'm getting Kat to take it into MR on Monday to get to the bottom of it - Southside just deny there is any unusual sound. Sheep
Post #7803 27th Feb 2009 3:57am
slocum
I'm with Russell, check your rear diff.
Post #7850 28th Feb 2009 2:54pm
Sticky
England 2016 Defender 130 Puma 2.4 HCPU Stornoway Grey
I have this problem with my March 08 110.
It is obviously outside the VIN range but the dealer checked and it has exactly this problem.
I am awaiting LR to approve machining by third party engineering workshop and hopefully all will be good finally.
The dealer has been superb in identifying issues and getting the work done, so no complaints with Hunters in Derby.
Post #7866 1st Mar 2009 8:20pm
slocum
My rear diff was replaced but the whine remains. I have a March '08 too! But my dealer wasn't so superb like your.
He had already replaced the following: front shaft, clutch, gearbox (!), transfer box and rear diff Big Cry
Post #7881 2nd Mar 2009 11:43am
