Home > In Car Electronics > Dual battery, fuse and terminals advice
bear100
About to tackle my first split charge install!
I have a Gwyn Lewis twin tray, a yellow top Optima and red top Optima plus a National Luna relay and controller.
Had an hour spare today and removed the existing battery, battery cover under the seat box and existing battery tray.
What I noticed was the existing positive terminal wont fit on the new battery, the existing Terminal is set at 90 degrees with an inline fuse and because the optima terminal is set further back it won’t fit plus the Negative terminal would be short.
How would be best to overcome this? Is there a terminal with built in fuse available? And best method to join the cables together to elongate?
How did you do yours? Thumbs Up 2023 Defender L663 V8
2010 110 XS Utility 2.4TDCI
1993 110 csw 200 tdi (gone)
1994 90 HT 300 tdi (gone)
1994 discovery 300tdi (gone)
90 hybrid 3.5 v8 (gone)
Post #779609 29th Jun 2019 10:16pm
bear100
Am I right in saying the existing size of positive and negative cable is 16mm? Extra flexible multi strand rated to 110amp? 2023 Defender L663 V8
Post #779682 30th Jun 2019 5:17pm
jonnyboy
United Kingdom 2005 Defender 90 Td5 XS CSW Tonga Green
Hello Dave
Not sure I fully follow your questions but here's my install - still running faultlessly nearly 5 years later
https://www.defender2.net/forum/topic36335.html
Jonny
Post #780990 10th Jul 2019 4:48pm
kmac
United Kingdom 2009 Defender 110 Puma 2.4 USW Santorini Black
hey bear100 - how did you sort this out in the end?
Post #799414 24th Oct 2019 11:29pm
