Home > Technical > Front ATB, flat tyre |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 16873 |
I imagine it would be ok since the front wheels will be loaded equally but I'd keep to moderate speeds. Alternatively why not put the spare on the back?
30th Jun 2019 10:31am |
aaronjp1990 Member Since: 25 Sep 2016 Location: shetland Posts: 4 |
Have one in the rear also. I’m guessing it shouldn’t be much difference from going round a corner anyway. Might just swap them and trundle home.
30th Jun 2019 10:56am |
hank Member Since: 12 Sep 2016 Location: South Wales Posts: 2231 |
Size difference is negligible; 3.8% - it will be fine. The diff is automatic torque biasing, not locked/welded so will just be like going round a permanent bend
Might trigger an ABS warning light as the sensor will pick up different RPM's. At 50mph on the 285 the 265 will be reading 51.9mph. As said though, I wouldn't run it too long like that > 110 XS Double Cab > Instagram @simonlanemind |
30th Jun 2019 11:44am |
Perfect thank you. Just to get it back home until the new one comes.
30th Jun 2019 12:17pm |
