![]() | Home > For Sale & Wanted > Centre cubby tray wanted |
'ere rossy have you seen Mary driving around Roscommon in her UK reg'd X type Jag ?,I sold it her, if so give her wave from me ![]() 1968 1/32 scale Britains 109 Pick up. |
mattlab Member Since: 16 May 2011 Location: suffolk Posts: 143 ![]() ![]() ![]() |
yes, i`ve got a cubby tray sitting in me shed, hows £20 plus postage, its as new if i remember correctly, but i will check. LIFE`S TOO SHORT TO DRIVE A BORING VEHICLE
rossy Member Since: 29 Nov 2010 Location: Co. Roscommon Posts: 1297 ![]() ![]() ![]() |
Ah sure I know Mary well ! There's only about a million Marys here ![]() |
spudfan Member Since: 10 Sep 2007 Location: Co Donegal Posts: 4813 ![]() ![]() |
Fitted a cubby box from Exmoor trim. You fit two bits of wood over the inspection tray using existing holes then screw your cubby box to the wood. Easily done and I am sure it will work for the Paddock's one. If you are unclear I will post photos. 1982 88" 2.25 diesel
rusty66 Member Since: 22 Jun 2010 Location: Rhineland Posts: 60 ![]() ![]() |
Used box-section alloy tube from local DIY store and rivnuts. Very nice finish and it's slightly raised which is good to rest arm on.
Box section comes in different heights/seizes so you can adjust to your body-size (armrest-wise) or could fit speaker, safe ... under cubby, too. Do have a spare tray, too. We could make a swap-deal as I'm after some small bits from the UK and they don't ship to something as far away and foreign as Germany. |
Lorryman100 Member Since: 01 Oct 2010 Location: Here Posts: 2686 ![]() |
I'm not after you're tray but if you drop me a pm containing info on the small bits you are after I can post them over for you and we could do a swap deal? All I would ask for in return is a bottle or two of apple Korn ![]() Brian. |
Cheers Boris, Apple Korn arrived today just in time for my long weekend off work
