![]() | Home > Wheels & Tyres > Borbet CW Alloys 8x16 - advice and weight supported |
| Sulisuli Member Since: 30 Oct 2016 Location: South west Posts: 4808
Fred95 a forum member from Germany has these fitted to his defender, maybe worth sending him a private message. Nice rims by he way
2008 SVX 90 2000 XS TD5 90 |
| Fred95 Member Since: 23 Oct 2011 Location: Gruenwald Posts: 9
Max load is per rim. This being said: you will be fine, since the max load per axle won’t exceed the max load of two rims.
| Mariol66 Member Since: 09 Jun 2012 Location: Perpignan Posts: 35
That leaves me 150 kg per wheel, I think also that in static weight it should have gone, but I imagined that in dynamic weight on a cant, the weight is transferred on one side or the other and I do not have no idea of the mass on each wheel at that moment.
If not Fred95 you have these rims? you're happy? would you have a picture of your Def with these rims? |
| sharkey964 Member Since: 05 Oct 2014 Location: On a muddy track Posts: 584
There is a picture in Fred95 gallery.
Thanks
No problem!!
Plenty of pictures here:
http://fred95-defender.blogspot.com/ Fred. |
Thank you Fred for the photos, your Defender is beautiful. If I translated your site, I understand that you have re-paint your CW Alloys rims in 2011. The original paint rims was fragile because you had them in 2009 and it seems little 2 years.
I bought them in silver. At this time, this was the only available color from the factory.
I let them powder coat in black. Not a regular paint. The powder coat did not stick around the valves. I got them re-coated. I believe even three times within ten years. The rims or Borbet are not to blame for that; only my stupid powder coater. Other than that: I recommend them. Relatively low weight (appr. 10 kg), perfectly round, easy to balance, easy to clean.
This is not, how you do the math (compare total weight against max rim load x 4). You have to compare the maximum allowed weight per axle and compare it against max rim load x 2. Maximum allowed weight according to your registration documents. Not actual weight. This must not exceed the max allowed weight anyway, or the police stops your car. The dynamic weight is irrelevant. At least for legal requirements. But if you watch the details: car manufactureres always apply a 20% safety premium on their original wheels and tires, when it comes to max load. I don't know, whether this can be contributed to the fact, that they pay attention to dynamic load, or are just careful. However, this is NOT a legal requirement. Fred |
I had done the math for a single axle. 925 - (1550/2) = 150 kg. but actually if it is the static weight these rims are ok compared to the maximum weight of the rear axle of the Defender Station Wagon (1750 kg). in any case if you only find good for these rims, it will motivate me lol. I only hope to find a professional able to properly balance 255/85 r16, the last time I had my tires up, it was catastrophic, I had to do two tires mounting centers.
