![]() | Home > Puma (Tdci) > Mountain light |
22900013A Member Since: 23 Dec 2010 Location: Oxfordshire Posts: 3153 ![]() ![]() ![]() |
On my pumas dashboard I can see a symbol that looks like a mountain, just below the rev counter I think. I have never known it light up, whats it for? Is it something to do with the same dash being in the disco? 2011 110 USW
1973 Series III 1-Ton 1972 Series III 1-Ton Cherrypicker 1969 IIA 1-Ton 1966 IIA 88" |
astoltz Member Since: 08 Mar 2011 Location: South Africa Posts: 31 ![]() ![]() |
It is the low range light.
I would like to find out if one can activate this light just because. The transfer case has the low range switch fitted. Me thinks it has been disabled from the instrument cluster software config?? 1997 Land Rover Defender 110 HT 2.8i (BMW M52) 2009 Land Rover Defender 110 HT 2.4 TDCi(Puma) |
Ah okay. I have had my truck in low range and didn't see it light up. I only saw it due to the way the sunlight was on the dash. 2011 110 USW
Toplink Member Since: 05 Dec 2010 Location: Somerset Posts: 159 ![]() ![]() |
Real defender drivers don't need an idiot light to tell them its in low range
![]() 2007 Defender HTop. 1952 Series One 80" 1977 Muir-Hill 111. 2014 Triumph Tiger800xc 1999 Discovery 2 td5 1982 Ransomes TSR300D. 2002 Yamaha XT600e. 2010 Freelander2 (the wifes) 2008 John Deere X140 |
pom Member Since: 01 Jun 2010 Location: Worcester Posts: 1343 ![]() |
A light to tell me i just reached down and moved a lever ![]() |
Apart from when you've been doing some delicate reversing manoeuvre with a heavy trailer in low box, you get out unhitch, get in forget your in low box and nearly snap your neck.
![]() 110 HCPU Tipper |
Glynparry25 Member Since: 16 Feb 2009 Location: Miserable Midlands Posts: 3015 ![]() ![]() ![]() |
Doing 30mph at max revs in 6th gear would be a good indication. Glyn ![]() ![]() |
