Home > Puma (Tdci) > Central locking fail
Pinky
England 2011 Defender 110 Puma 2.4 DCPU Baltic Blue
Hi, has anyone any idea what might have gone? I unlocked the 110 with the remote and the lights flashed as normal but the thing remained locked. Subsequent presses of the remote did nothing, no lights or anything. I cautiously opened it with the key expecting the alarm to go off but again, it just opened the one door, the others remained locked, I can’t seem to find a dedicated fuse for the central locking so don’t quite know where to start! Any help gratefully received 👍🏻
Post #779147 26th Jun 2019 7:51pm
Martin
Site Admin
Fuse 6 (15A), Fuse 7 (20A) in the battery box fuse box.  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #779173 26th Jun 2019 10:48pm
Pinky
Thanks, but you will have to be more specific. The battery box has nothing but the battery in it, the drivers seat box has relays and a few fuses, the in dash box has fuses. Non relate to 6&7
Post #779174 26th Jun 2019 11:06pm
Martin
Site Admin
Alright, I'm trying to help.
It's called the "battery box fuse box" on the wiring diagram. Sorry, it's the seat box fuse box.
I'm assuming that this relates to your 2011 Puma as per your icon.
In which case there are 6 fuse links and the first 7 numbered blade fuses in the seat box fuse box.
Then blade fuses numbered 8 through to 47 under the panel beneath the steering wheel.
I've given the exact fuse numbers and ratings, I got the common name of the fuse box slightly wrong.  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #779175 26th Jun 2019 11:17pm
Martin
Site Admin
From what I can see, fuse 7 has an icon of a car door and key in the fuse box lid label. Looks likely.  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #779176 26th Jun 2019 11:22pm
Pinky
Thanks, I’ll take a look when I get to work.
Post #779188 27th Jun 2019 7:27am
Doc P
United Kingdom 2013 Defender 110 Puma 2.2 XS CSW Firenze Red
.........and once/if you find a blown fuse, look for the broken wire(s) between a pillar and a door (the one with the actuator that doesn't work) which caused the short!
Post #779203 27th Jun 2019 9:49am
Pinky
Yep, blown 20 amp.
Doc P, all the actuators work so it’s either a partial break or just one of those things! If it happens again I’ll investigate further.
Post #779212 27th Jun 2019 10:37am
Pinky
UPDATE
After this continued to happen randomly and all wiring in the doors checked and confirmed sound I looked at the remote itself.
turned out to have a broken solder joint. I re-soldered it and problem solved!
Post #781335 13th Jul 2019 11:53am
