![]() | Home > Puma (Tdci) > scraping noise |
ickle Member Since: 22 Jul 2010 Location: South Vendee Posts: 1858 ![]() ![]() ![]() |
pads worn out
stone in calliper stone behind disc cover wheel bearing gone...? |
claydiggermud Member Since: 11 Jul 2015 Location: west country Posts: 86 ![]() ![]() ![]() |
thanks i take a wheel off and have a gander
zsd-puma Member Since: 09 Aug 2016 Location: Kent Posts: 2720 ![]() ![]() ![]() |
Drive it in reverse for 20 yards or so, if there is a stone in there then it might be enough to flick it back out again.
It could even be a splashguard broken and rubbing on the disc. Im pretty sure the cause will be obvious once you get your head under there. |
GREENI Member Since: 22 Aug 2010 Location: staffs Posts: 10387 ![]() ![]() |
I once thought a gearbox was fudged having a stone between the disc and guard before now.
It once happened on an A5 we had, a few wiggly reverse laps of an empty car park cured it. QRZ 2e0vpf |
Taken the pads out and it’s still the same so I think it’s to do with the drive shaft ?
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20964 ![]() ![]() |
Are the driveshaft splines lubed or do you have one piece at leat on the rear?
If check those wheel bearings whilst at it too. I think most of us have had a stone in the brakes before! One I had years ago was a real sod to shift it really was involving interesting reversing moves as mentioned above! ____\We|Will|Win/___ ____/🇬🇧🇺🇸\____ _//*⛽️🛢️⚙️🧰*\\_ |
Check the retainer springs and pins aren’t squeaking too, they’ve been known to do that. ____\We|Will|Win/___
I think it’s the wheel bearing but unable to remove the nut, I have the big socket but won’t budge
Any suggestions I have sprayed penetrating oil on but the socket just slips of ![]() |
neon1991 Member Since: 26 Mar 2018 Location: Colchester Posts: 101 ![]() ![]() ![]() |
you mean the big hub nut?? I usedan inpact driver to get mine off. making sure you've un flattened the locking bit on the nut first or you'll never get it off.
