![]() | Home > Puma (Tdci) > Clutch Slave GONE!!!!! |
![]() ![]() ![]() ok, new parts ordered...... Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition ![]() IID Pro MV License |
wyvern Member Since: 14 Dec 2009 Location: Cornwall Posts: 2149 ![]() ![]() ![]() |
YIKES!!
poor you ! We had the same thing go on Poppy (2.2 110 ) last year ... big pain !! ![]() Gives you an opertuity to pop in an uprated clutch though ! ![]() all the best with the beast ! ![]() Elgar -TDCI(Puma) 110XS Dormobile - now sold Devon & Cornwall 4x4 Response - DC126 ![]() |
Ciao wyvern,
yes Transit 4x4 clutch ready (bought 2 years ago). It is THE solution! More than 35 Defenders here with this clutch, never had a problem! http://www.africaland.it/forum/viewtopic.php?f=10&t=74203 Use with Chrome with translator to read it in EN Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition ![]() IID Pro MV License |
Roy5695 Member Since: 15 Feb 2014 Location: Cornwall Posts: 1123 ![]() ![]() ![]() |
Worth changing the rear crank seal while you’ve got the box off, also check the t/box to G/box adaptor shaft 2011 Defender DCPU 2.2 - https://www.defender2.net/forum/topic30623.html
Instagram - @r22oyp Roy |
Yes! Thank you Roy Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
