![]() | Home > Td5 > TD5 air conditioning wiring |
| dorsetsmith Member Since: 30 Oct 2011 Location: South West Posts: 4554 |
pic missing PC problems
| jrule Member Since: 10 Aug 2015 Location: Hertfordshire Posts: 302
Many thanks that's very good of you. Looking at the diagram it appears I need to wire back to relay R181 and R117. Do you have access to any diagrams that show where these are located if not it seems I will need to make up a loom ?
two relay are located in drive seat box
Ah excellent I shall have a good look
| Catalou66 Member Since: 24 Jun 2019 Location: Paris Posts: 2
Hi,
(Sorry for my English because I’m french) I want also to install an Airco coming from a Defender TD5 99 to my Defender TD5 06 but it looks like the pics you posted has disappeared. May you post them again? I really would appreciate it. Thanks a lot in advance! |
| Steve_overland Member Since: 14 Oct 2018 Location: Gaydon Posts: 294
I can’t see them either... will the diagrams work for 300tdi.. cheers @steve_overland on Insta.
110 expedition vehicle with pop roof |
link to TDI 300 wiring AC too
https://1drv.ms/b/s!AtZSoWFHDgnGjD447hxdHo-gv_oL Last edited by dorsetsmith on 25th Jun 2019 6:53am. Edited 1 time in total |
Ac fuse are different places between TD5 99 and TD5 06 main loom as the centre fuse box changed post 02 face lift will re post then Last edited by dorsetsmith on 25th Jun 2019 7:22am. Edited 1 time in total |
Click image to enlarge Click image to enlarge MY 1999 to 2000 Last edited by dorsetsmith on 25th Jun 2019 8:43am. Edited 1 time in total |
| Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6728
Td5 and 300 Tdi in here (2002MY):
https://www.defender2.net/gallery/albums/u...IONING.pdf 1988 90 Td5 NAS soft top
2015 D90 XS SW |
Thanx a lot!
| MYSTERY Member Since: 14 Jun 2019 Location: Torquay Posts: 10
ONE SHEET
Click image to enlarge |
| achuakh Member Since: 12 Apr 2012 Location: Singapore Posts: 161
technically, you don't need to get the AC unit to talk to the ECU.
Pro: When it's wired to the ECU, the ECU can control when to "request AC clutch" and when to "request AC fan". When the driver turns on the AC, he "request AC" to the ecu via the 12v AC request at high. The ECU then checks the operating conditions like engine temperature and engine rpm. If the temperature is ok and the engine is not labouring, the ecu will then "request AC clutch" and then "request AC fan". If the engine temperature is high, the ECU can also use the "request AC fan" to aid cooling If the engine rpm is high, then it will not immediately "request AC clutch" When "AC clutch request" is made, depending on the RPM, there's a table in the ECU map to inject more fuel and it tapers down around 4000rpm. Con: Let's not complicate the install as you will need to mess around with the ECU pins and such to get those to close the correct relay. If using a manual AC unit, when the AC clutch and fan are on, the ECU will already know how to compensate for the drop in RPM when idling so there's no adjustment to do. Having a separate AC system from the ECU is easier to isolate if something goes wrong. The defender has migrated, leaving the owner behind. |
| All times are GMT |
