![]() | Home > In Car Electronics > Mystery trip reset. |
boxoftricks Member Since: 06 Feb 2019 Location: Home Counties Posts: 748 ![]() ![]() ![]() |
Just saw this in another thread:
https://www.defender2.net/forum/topic48404.html Halfway down the first page is what you need. |
lonewolf Member Since: 23 Oct 2013 Location: North East England Posts: 210 ![]() ![]() ![]() |
Thank you for your info.........I assume you’re referring to the little diagram showing the eart locations.
It’ll be a start anyway ![]() |
Yep
My first port of call would be the battery terminals. The ones used on Pumas are particularly rubbish and have a habit of working loose. I packed mine out with shims made of copper to enable them to grip better. Darren
Rev the battery terminals: yesterday I checked mine and although they looked nice and clean and nicely fastened I found that I coils do still rotate the earth connection. This has now been tightened up although I did have to jam a flat bladed screwdriver against the head of the bolt head to stop it from turning when I tightened the nut. It’s much tighter now so I’ll se if I get the trip reset and radio demo again.
Thanks to all for your input. |
Please excuse the predictive text typos......I knew I should have put my reading specs on......doh !
