Home > Technical > Tacho install - how to set VDO gauge switches vs 'pulses'?
donmacn
Hi,
I've just got a new VDO analogue rev counter to fit to my 300Tdi.
It has three micro-switches to set for 4 cyl engines, and RPM range, but the instructions are on about various 'pulses'. I tried to search for this, and didn't get anything relevant.
Can anyone help? Where do I find that info, or what setting do I use?
Thanks Donald
2000 Range Rover P38 4.0L V8
in the past..
1993 Discovery 300Tdi
Post #778163 19th Jun 2019 6:27pm
dorsetsmith
https://forums.lr4x4.com/topic/99198-that-...tdi-query/
switch 1 to off
switch 2 to off
switch 3 to on
Post #778175 19th Jun 2019 7:52pm
donmacn
thanks for that - I was just on there looking at tacho threads but hadn't found that one.
The switch locations are what I was after though, so that's me sorted. cheers.
There's also a handheld, laser tacho linked from that thread for less than a tenner, which seems like a good idea for fine tuning.
Ta Donald
in the past..
Post #778178 19th Jun 2019 8:08pm
donmacn
Just been thinking about this some more - I'll try asking this simple question here first rather than starting a new thread.
Having ordered a handheld laser tacho as above (£8.50 including postage - rude not to) where do I measure the revs to fine tune or confirm the VDO gauge reading?
If I measure the crankshaft pulley is that one revolution or four? Would one revolution of the crankshaft equate to one revolution of the alternator pulley, or is there some sort of reducing (or magnifying) effect via the serpentine belt and different diameter pulleys? Donald
in the past..
Post #778207 19th Jun 2019 10:00pm
Martin
Site Admin
Alternator pulley is much smaller than the crank pulley so it spins at a multiple of the crank speed.
300 Tdi ratio is roughly 2.5 or roughly 3 depending on which alternator pulley is fitted.  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #778244 20th Jun 2019 11:20am
donmacn
Thanks Martin, I'll see if I can find a spec for my alternator pulley at some stage.
Am I right though that one rotation of the crankshaft = one engine revolution? That sounds right intuitively - I can't see how it could be anything else - but best be sure! Donald
in the past..
Post #778289 20th Jun 2019 5:39pm
