![]() | Home > Puma (Tdci) > Puma clock |
| Balvaig Member Since: 19 Feb 2016 Location: Fife Posts: 737
Mine gives me an approximate indication of the time, needing some adjustment every three months. It is after all a forty year old design in a Defender
| gilarion Member Since: 05 Dec 2013 Location: Wales Posts: 5142
My clock has stopped at 2.15 though I have to say it is accurate to the minute twice a day.
I always thought a quartz movement would be far too modern so JLR knowing the water ingress of the Defender opted for the water clock movement. So depending on the water drop frequency behind the dash it will either run slow or fast http://www.youtube.com/user/conwy1 |
| williamthedog Member Since: 29 Dec 2012 Location: south wales Posts: 3441
Mine is fairly accurate, very rare I have to alter it. Usually putting forward or back for the spring /winter is the only time I touch it.
| Rosco Member Since: 03 Dec 2010 Location: Burntwood Posts: 1876
The accuracy of mine varies on the little passengers and their incessant need to press everything
2002 - Black Discovery II - Gone 2014 - Montalcino Red 110 XS SW |
| ericvv Member Since: 02 Jun 2011 Location: Near the Jet d'Eau Posts: 5817
Only have to change the time twice yearly. For winter and summertime adjustment. Otherwise keeps the time perfectly.
Eric You never actually own a Defender. You merely look after it for the next generation. http://youtu.be/yVRlSsJwD0o https://youtu.be/vmPr3oTHndg https://www.youtube.com/watch?v=_GtzTT9Pdl0 https://www.youtube.com/watch?v=ABqKPz28e6A https://www.youtube.com/watch?v=rLZ49Jce_n0 https://www.youtube.com/watch?v=XvAsz_ilQYU https://www.youtube.com/watch?v=K8tMHiX9lSw https://m.youtube.com/watch?v=dxwjPuHIV7I https://vimeo.com/201482507 https://www.youtube.com/watch?v=ZSixqL0iyHw |
| Gladys Member Since: 28 Nov 2015 Location: South Wales Posts: 36
Thanks chaps. Sounds as though mine is faulty then. I might have to take the lid off.....
| All times are GMT |
