![]() | Home > Maintenance & Modifications > Td5 fuel pump replacement |
LandRoversofLondon Member Since: 07 Jul 2016 Location: London Posts: 22 ![]() ![]() |
The fuel pump on my Td5 has packed up and needs replacing. I’ve been quoted £650 to get it replaced, is this the going rate for a job like this? I’m against cutting a hole in the floor which I know would be cheaper! Instagram @LandRoversofLondon
www.instagram.com/landroversoflondon |
Intercept Member Since: 27 Feb 2017 Location: Suffolk Posts: 587 ![]() ![]() ![]() |
Mine died last year and was replaced with a genuine unit by a local indy and the bill was near £1K, so £650 sounds quite cheap by comparison.
jaygti Member Since: 04 Nov 2012 Location: essex Posts: 403 ![]() ![]() ![]() |
I paid £700 inc genuine part , so I sounds fine👍🏻 2002 td5 90 county hardtop
diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6205 ![]() ![]() ![]() |
Get a discovery pump.... exactly the same as defender bar the float arm, which unclips from both types.
disco one is (well, was a few years back) substantially cheaper. |
TJH1985 Member Since: 22 Aug 2016 Location: Midlands Posts: 241 ![]() ![]() |
I fitted a Valeo OEM pump to mine and it was still £200!
I didn’t cut any holes etc, it wasn’t that much work to drop the tank. |
Just be aware that the fuel line connectors on a TD5 can be fragile.
If the plastic connectors break choices are new fuel lines from LR at about £250 or a set of replacement fuel line connectors Brendan |
miker Member Since: 13 Sep 2015 Location: Surrey Posts: 1789 ![]() ![]() ![]() |
About £50 cheaper for the VDO disco once to the VDO defender one currently, still both quite painful at over £200 ![]() |
Too right... This is the main reason for not dropping the whole tank and doing the inspection hatch in the floor modification. From experience, so very fragile. I ended up with a Bearmach pump as it was the only one I could get next day. It works well, but is good lord it is much MUCH noisier than the VDO unit I took out. |
I have a replacement pump in my boot currently, awaiting me to have some spare time, or complete failure of the fitted one! Current trick is it won't start when the tank is less than 1/3rd full unless I run a purge cycle first.
Still haven't decided whether to drop the tank or cut the hole though, how have people repaired the hole afterwards? |
excossack Member Since: 22 Feb 2012 Location: North West Posts: 6018 ![]() ![]() ![]() |
Mine is similar, if less that 1/4 of a tank it starts, then cuts out unless I have my foot to the floor and then the engine pulls through and works fine. 1999 Defender TD5 110
Replacement fuel line connectors kit
![]() ![]() Click image to enlarge |
Boyd Member Since: 11 May 2014 Location: Le Saint Posts: 172 ![]() ![]() ![]() |
![]() ![]() Any hints and tips appreciated, as i'm just going down this road and am struggling to find replacement connectors or pipe joiners that are cheaper than the Nakatanenga £36?! Anything appreciated ![]() 2004 Santorini Black TD5 110 XS SW left hooker for sale! 2004 Alpine White TD5 110 left hooker (work in progress) |
Justtellme Member Since: 23 Nov 2015 Location: Ottawa Posts: 310 ![]() ![]() ![]() |
Did you find a cheaper source for these connectors?
Patrick |
LandymanStefan Member Since: 30 Aug 2017 Location: Surrey Posts: 881 ![]() ![]() ![]() |
I did a hole during lockdown.
Fuel pump doesn’t need replacing yet but it’s 20years old so I thought while I had the time I’d get it ready so it’s an easy job when it comes ![]() Click image to enlarge |
