Home > Technical > Solar Panel Mount |
davew Member Since: 02 Jan 2012 Location: North Yorkshire Posts: 888 |
Not a Land Rover but the same principal would work...
Click image to enlarge A semi-flexible panel using 3m VHB tape to secure it to the roof. In this case a back contact, 150w panel. You can also use SikaFlex but the tape is easier to deal with if you have to change the panel. Just make sure you don't get one with the rear connection box. http://www.yorkshireoffroadclub.net/ |
13th Jun 2019 1:19pm |
Steve_overland Member Since: 14 Oct 2018 Location: Warwick Posts: 274 |
Thats cool, but i already have a rigid one .... Building a 110 expedition vehicle, pictures can be found: @steve_overland on Insta.
14th Jun 2019 12:04pm |
Bluest Member Since: 23 Apr 2016 Location: Lancashire Posts: 3993 |
Not the cheapest, but the Cargo Bear roof bars can be had in a style that slopes down with the roof 2007 110 TDCi Station Wagon XS
14th Jun 2019 1:57pm |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5408 |
Apparently the ones you fit directly to the surface, and that don’t have an air gap underneath overheat. That’s what I have read on the subject. Obviously that will depend on where you go.
Many people just bond the brackets to the top of their motorhomes. |
14th Jun 2019 8:32pm |
That's kind of correct but for the wrong reasons... It's not that they overheat as such, more that there can be issues that the panel expands and if it's securely bonded to a roof that doesn't expand at the same rate bad things happen. When they are lifted off the roof slightly and not bonded all around that allows the panel to expand and bend slightly. This has been mistaken for "overheating" but the panels simply fail due to the mechanical stresses involved when they can't expand. This can be made even worse if air is trapped between the panel and the roof as, again, the air expands and stresses the panel from underneath. When installing on a flat surface you should bear that in mind... a bit like installing a laminate floor and forgetting to leave an expansion gap. http://www.yorkshireoffroadclub.net/ |
16th Jun 2019 12:25am |
