Home > Maintenance & Modifications > Terrafirma NAS Bar fitting instructions |
LCJ Member Since: 07 Sep 2009 Location: UK Posts: 201 |
I know it says Britpart but I’ve got a terrafirma one and it’s exactly the same: https://www.paddockspares.com/downloads/STC50301_vr1.pdf
12th Jun 2019 7:31pm |
tyrannosauROSS Member Since: 24 Jun 2016 Location: Kent Posts: 136 |
Thanks.
These are identical to the ones I found on extreme 4x4's website. I think I have it in now, except the two 120mm bolts, which in my kit are 130mm and guess what?, they are 10mm too long!! Now I need to go and buy some that are the right size, I dont want to cut them down because the are BZP. Grrrr.... nothing ever fits first time! I also have in my kit 2x T shaped pieces that have two holes drilled in them. I can't find them mentioned in the instructions anywhere. |
12th Jun 2019 8:20pm |
OJ Member Since: 23 Nov 2018 Location: North of Edinburgh Posts: 120 |
The T shaped bits fit inside the crossmember at each outer end where the bolts attach, stops the crossmember distorting when you tighten the bolts up, the T part helps you locate it, check if you have two heavy spacers that fit onto the long bolts that take up the extra 10mm
Cheers OJ |
17th Jun 2019 3:19pm |
