![]() | Home > Expedition & Overland > Im in the penman club!! |
GREENI Member Since: 22 Aug 2010 Location: staffs Posts: 10387 ![]() ![]() |
smb Member Since: 15 Jan 2013 Location: Cheshire Posts: 1233 ![]() ![]() ![]() |
I’ve just enquired about buying one to replace a mk3 and they want £750.00+VAT
A visit with 'cash' ![]() |
roliver Member Since: 24 Nov 2016 Location: Cambridge Posts: 60 ![]() ![]() ![]() |
Certainly cheaper than what John Richards or Witham want for them (£850-£1250 +VAT). Will they tow with a light board on the back or do the electrics need to be converted before they'll go anywhere? |
Devon-Rover Member Since: 22 Jan 2015 Location: South Devon Posts: 926 ![]() ![]() ![]() |
When I picked mine up I just cable tied a lightboard on the back to get home.
![]() Click image to enlarge Also can be found on Fb, Ytube, Insta & Twitter @4WDSouthwest |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17993 ![]() ![]() ![]() |
Devon-Rover, on the type you have do the front, sides, and back all detatch, and corner posts too, leaving a flat deck if required?
That version, which I've seen described as "lightweight", looks very handy. |
Hi.
Yes all the sides and tailgate detach but the corner post's don't, they are fixed to the bed. It is called the Lightweight as the name plate has the rather extravagate naming of.. TLR LW 1.13T 2WHD Special Role So I Assume it means Trailer Lightweight 1.13 Ton Two wheel Heavy Duty Special role. Essentially it is a generator trailer having seen them with 5.5 and 15KVA generators and the support frames bolted to them. Also can be found on Fb, Ytube, Insta & Twitter @4WDSouthwest |
diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6216 ![]() ![]() ![]() |
Last week I bought one as well. HAs been rolled, so the tub has a bit of a kink in it... might just get a replacement one.
Brakes have been cannabilised but I managed to pick up a complete axle yesterday, so just need a master cyl and the upgraded valve PRV unit (if anyones got one?) Towed lovely behind my 110. |
Whirly90 Member Since: 01 Sep 2016 Location: Ampshire Posts: 412 ![]() ![]() ![]() |
Jim - i've got a tub in excellent condition i'm about to put up for sale.
PM inbound...
Replied
