Home > Technical > Heater matrix
Procta
Heater matrix
For some reason, my heater matrix seems to be stuck on warm, any ideas on that? I have gave the controls a spray down. I have gave the top wire a spray on the heater box too. But nothing, Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
In the words of my Good Friend, Gary Forrest 1980 -2025
" we will work something out"
Post #776446 7th Jun 2019 6:08am
landy andy
Disconnect the lever on the top of the heater box (under bonnet) and operate lever manually.
How does it feel?
Can you hear it move/close flap?
Does it stop the heat on test drive?
Post #776449 7th Jun 2019 6:46am
geobloke
As above. likely to be either a slipping cable or a broken cable.
Post #776452 7th Jun 2019 7:31am
donmacn
... even a visual check? Note the position of the lever on top of the heater, move the cable, is the lever moving at all?
It's a really basic thing. I have some pics somewhere of a dismantled heater, which from memory shows how the lever/flap works - if that would be any use to you. Donald
2000 Range Rover P38 4.0L V8
in the past..
1993 Discovery 300Tdi
Post #776462 7th Jun 2019 9:21am
Paddie42
England 2003 Defender 110 Td5 SW Belize Green
I had a similar issue where is was very stiff to move the selector.
I removed the cable from the lever ontop of the heater box in the engine bay. Where the cable joins the lever there is a joint that should move so that the cable is always in the correct position to the heater matrix. This was very stiff. Some 3-in-1 oil and a little patience got this moving again.
The cable was also a little stiff, so some 3-in-1 on that helped as well.
I hope the above makes sense. Happy to take picture if it helps.
Post #776483 7th Jun 2019 12:01pm
Procta
yeah lads get me some snaps, just so I have a good idea on what why and when, The old landy was spot on, but this one seems to be on constant warm or hot. Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
Post #776513 7th Jun 2019 4:09pm
Procta
I gave this a spray down and looked at the control on the heater box itself, on cold its pointing horizontal, then it moves to the driverside for the hot air, so I am suspecting something not right there. Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
Post #778463 21st Jun 2019 9:24pm
donmacn
Hey mate,
I mentioned pics a while ago - and then forgot Big Cry
I haven't got them here at the moment, but I did post them on this thread: https://www.defender2.net/forum/topic60066-30.html
If you can, have a look and see if that helps?
The flap in the box isn't sprung at all, so any movement will be coming from the cable. Donald
in the past..
Post #778468 21st Jun 2019 10:25pm
Procta
its moving, I am suspecting that the cable is seized. I will have bum up to my dad with his, just in case, mine is ok, and there is something else wrong Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
Post #778515 22nd Jun 2019 3:52pm
landy andy
You have previously mentioned that the spacers were missing from the in cab controls. Did this bend / kink the cable too tight? Maybe worth disconnecting both ends of the cable straightening as much as poss and work it back and forth.
Post #778517 22nd Jun 2019 4:14pm
Procta
you know something, now that you mention it, I think I will buy the proper spacers and a new cable, in case that's been damaged as you say. Thumbs Up Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
Post #778521 22nd Jun 2019 4:55pm
