Home > Maintenance & Modifications > Removal of rear jump seats 110
TheShrink
Hi,
I am not mechanically minded although love giving it a go.
One job I want to do ahead of the summer is remove the rear most seats (2 forward facing seats) in my 110 (Reg: 2010).
Although it looks simple the screw head on the bolts attached to the chassis appears to be different. I wondered if anyone had an 'idiots guide' video or similar that could guide me through. It looks straight forward enough but I don't know the tool that I need.
Thanks in advance - really enjoy reading everyone's posts and getting courage to 'tinker'.
Thanks
Post #776050 3rd Jun 2019 2:31pm
Rosco
United Kingdom 2015 Defender 110 Puma 2.2 XS CSW Montalcino Red
This is a pretty decent how to
https://www.defender2.net/forum/topic39220...at+removal
Hardest parts are probably extracting the plastic screws from the caps covering the hinges, as the heads are made of choclate and easy to ruin (I found a trim removal tool to exert a littel leverage helped) and the finally lift out the back when you realise they weigh as much as a baby rhino 2007 - Stornoway Grey 90 XS SW - Gone
2002 - Black Discovery II - Gone
2014 - Montalcino Red 110 XS SW
Post #776056 3rd Jun 2019 3:14pm
JOW240725
There are several thread on this if you try the search function. The best seems to be this one... https://www.defender2.net/forum/topic39220.html
Good luck Thumbs Up James
Instagram @suffolk_rovers
Post #776057 3rd Jun 2019 3:15pm
TheShrink
Thank you James - that thread is exactly what I needed.
I am very grateful for the responses.
Best wishes,
James
Post #776066 3rd Jun 2019 4:48pm
Mies
Netherlands
Removed both yesterday to install soundproofing and carpet. Then installed them again. Nothing to go wrong basically if you have the right socket. Don’t forget the two 13mm hex nuts under each rear wing.
As said above; they are heavy! If you plan to leave them out don’t forget to put the bolts back in and have four m8 bolts with washers and nuts ready to cover the remaining bolts. Lots of water and noise will come in otherwise.
Post #776084 3rd Jun 2019 7:42pm
