![]() | Home > Td5 > Power cuts out on motorway |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5986 ![]() ![]() |
What did the temp gauge say/do during this?
jtyrie Member Since: 28 May 2019 Location: Yorkshire Posts: 4 ![]() ![]() |
I didn’t notice anything on the dial, think it just stayed in the middle
If the temp gets too hot, then it will cut the power. On td5s the temp gauge is a magical device. Part real, and part false, the first half works as norm, then half and above is controlled by ECU and will make it enter limp mode. That’s basic terms.
Also can be triggered by loose relays, or bad earth to relay, fuse mount under drivers seat. But all these tend to display by the gauges doing odd things. Do you think it may be a heat issue? |
Yes if I had to guess I would have said something heat related.
I didn’t notice anything with the gauges. Anything obvious to check if it’s heat related? Cheers! |
Without more context there are lots of possibilities:
Rad blocked (both internal and external) Viscous fan operating as intended Water pump Coolant level Brakes binding Thermostat Temperature sensor Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
I would check the basic cooling stuff.
Check rad isn’t full of mud (not unknown of in a Defender) Viscous fan is doing what it should, and is complete Fan cowling is complete Water/coolant level ok Coolant system free of air. How hard were you pushing it? |
Retroanaconda Member Since: 04 Jan 2012 Location: Scotland Posts: 2763 ![]() ![]() |
Surely the whole point of a Td5 is that you can plug it in and the computer tells you what the fault is, or at least gives you an idea?
Hufflepuff Member Since: 25 Oct 2014 Location: Hampshire Posts: 727 ![]() ![]() ![]() |
I think I would be checking the injector loom coming out of the rocker cover for signs of oil ingress too.
Oddly enough I did once have a similar symptom in torrential rain on the M3, cruising along when suddenly it felt like the engine cut out temporarily, just for 2 to 3 seconds or so, which then cleared for about a minute and repeated. Gave me a pretty big shock at the time as I was in the fast lane above the spray of all the other cars who had slowed down significantly with the spray. I never found out what caused it, I assume water got into somewhere where it shouldn't. It hasn't done it again to me in the last 3 years. 2005 Td5 90 XS 1989 V8 110 CSW |
pj2106 Member Since: 20 Dec 2012 Location: Huntingdon AKA The Shire Posts: 1500 ![]() ![]() ![]() |
First port of call check intake is t blocked and filter is in good condition if also check pipe from airbox to turbo these are known to collapse 2008 110 2.4 XS Utility (Hagrid)
2002 90 TD5 Hardtop (Sully) Sold 1998 300TDi D1 (Billy) Sold |
Any recommendations for a fault code reader, or am I best getting a garage to have a look? Thanks for all the suggestions I’ll have a look over it on the weekend |
