![]() | Home > Maintenance & Modifications > Swivel Seals Upgrade, should I do bearings too? |
I have a leaking swivel seal and will be replacing the pair. Should I do the bearings too, given I'll be taking everything apart? 60km vehicle, with (as far as I know) original bearings. If so, what brand?
![]() I've not been everywhere, but it's on my list..... 2011 Puma 110DC - Corris Grey |
hank Member Since: 12 Sep 2016 Location: South Wales Posts: 2352 ![]() ![]() ![]() |
They are not bank breaking so may as well. I would recommend Timken for quality aftermarket.
Although I can understand why people wouldn't bother given that seals are penny parts whereas quality bearings are maybe £25 - £30 each for aftermarket or £45 - £50 each for genuine so it turns a few quid job in to maybe a couple of hundred Could get the bearings in then strip/inspect the condition. Can always return them > 110 XS Double Cab |
boxoftricks Member Since: 06 Feb 2019 Location: Home Counties Posts: 748 ![]() ![]() ![]() |
Another vote to say yes and to go for Timkin bearings. If you’re stripping everything down it’s hardly any extra work. Also worth checking brakes for wear.
Thank you all. New bearings (Timken is what I was looking at) it is.
Will also check for pitting, fingers crossed seem to be ok from external inspection. New pads were fitted under 2000k ago, so all good there. Cheers Monsieur Le Grenadier I've not been everywhere, but it's on my list..... 2011 Puma 110DC - Corris Grey |
epictrail Member Since: 21 Sep 2013 Location: High Wycombe Posts: 395 ![]() ![]() ![]() |
Also Worth fitting Stainless Steel Swivel Oil Seal retainers while you're there. Stiffer than standard so helps stop Oil seal leaks.
RRY500180SS https://www.lrdirect.com/RRY500180SS-Swive..._https=yes |
Thanks EpicTrail, good thinking. Will definitely order these.
kmac Member Since: 07 Oct 2009 Location: Middlesex Posts: 1317 ![]() ![]() ![]() |
What locking nut system will you use? If the newer type you will need to measure and adjust the end float when putting everything back again.
oneten110 Member Since: 02 Jul 2011 Location: Wish I was still in France Posts: 741 ![]() ![]() |
For goodness sake don't buy the bearings from any form of car parts supplier. Go to a bearing specialist, they will charge you far less than any land rover dealer or specialist, same for the seals. It is not a Defender, it is a One_Ten
